Important features for choosing a car vacuum cleaner
According to the principle of operation, car vacuum cleaners do not differ from stationary ones. They also manage their tasks well, leaving a perfectly clean surface. Only designed to work with small areas. Some features of such models are as follows:
  • Compact size: more convenient and faster to move it in the cabin.
  • Light weight: as a rule, not more than 1.5 kg., Which is very convenient, because hands do not get tired during harvesting.
  • Low power: not much sits the battery of the car.
  • Presence of additional nozzles: it will be possible to work with different surfaces.
Budget devices as a dust collector are equipped with a bag that can be removable or reusable. And models of a more expensive class have plastic containers.
Main types of car vacuum cleaners
Devices differ in the type of cleaning: for wet or dry. There are also models that can work in two modes. Detergent vacuum cleaners are equipped with the function of collecting liquid, dirt and sand. They are well suited for the rainy season or snow. Dry-cleaning devices can only cope with dust and small debris.
Also, the vacuum cleaners differ in the type of filter. The aquafilter can capture small particles, is present in models of budgetary and middle class. The HEPA filter shows better efficiency and is able to hold the smallest particles, which is ideal for people with allergy to dust.
Important criteria for choosing car vacuum cleaners
To find the model that best suits your needs, you need to consider the important selection criteria:
  • Type of cleaning. If you only need to remove dust from time to time, it is advisable to choose a vacuum cleaner for dry cleaning. But more practical is the washing model, because at any time you can do a wet cleaning.
  • Dust collector. Easier to use the design with a removable element, since it can be washed. The volume varies between 0.2-0.7 liters. On the one hand, the larger the dust collector, the less it is necessary to clean it, but on the other hand - the vacuum cleaner will be heavier.
  • Equipment. It is important to decide what kind of attachments you will need so that you do not overpay for unnecessary ones. By the way, if you liked the model, but the equipment does not suit you, you can buy the details you need separately.
  • Source of power. You have three options: from the cigarette lighter, own battery or both. Of course, the latter option is more practical, but such models will cost considerably more.
As for the technical characteristics, they are less important in the matter of choice. The only thing we recommend is paying attention to the power, in particular, to the nominal value. Up to 75 W suitable for normal cleaning, the value is more appropriate to use for commercial purposes.
Vacuum cleaner for the car to buy in Kharkov, Kiev, Odessa with delivery across Ukraine it is possible on 130.com.ua.
Best vacuum cleaners for cars
Looking for a quality and the best car vacuum cleaners? This rating of car vacuum cleaners is made on the basis of such parameters as: high demand with positive feedback from our customers, high-quality manufacturing — absence of factory defects and service calls, and official warranty and post warranty support in Ukraine.
Car Vacuum Cleaner HEYNER CyclonicPower PRO 240
Features:
  • ★ Powered by car cigarette lighter
  • ★ With double filtration system
  • ★ The maximum power is 138 W
Vacuum cleaner for car Daewoo DAVC 100
Features:
  • ★ Suitable for wet cleaning
  • ★ Quick detachable dust collector
  • ★ Cyclonic filter
Car vacuum cleaner VOIN V-80
Features:
  • ★ for dry and wet cleaning
  • ★ with two motors
  • ★ suction power 5800 Pa
See video reviews of auto vacuum cleaners:
Car vacuum cleaners: Best Sellers
