Car vacuum cleaners: how to choose the ideal model for yourself
Clean interior is not only positive emotions for passengers and the driver, but also comfortable conditions for movement. Visit often car washes, not everyone has the opportunity in finance and time. A practical option for drivers is the presence of a car vacuum cleaner, which can always be at hand and help to quickly clean the interior of dirt.
To begin with we will be defined with types of devices:
- Washing: for wet cleaning-ideal for bad weather, especially in autumn and winter, when there are many traces of snow and puddles. There are models with different sizes and functions. This is a universal option, because you can perform both dry and wet cleaning.
- For dry cleaning-the standard option, most often designs of small sizes. Modern versions of devices are equipped with various functions, filters for more efficient cleaning.
The choice of design depends on your desire and capabilities: detergents are more functional, for dry cleaning they are economical.
Important parameters: be sure to note
All models differ not only in appearance and size, but also in technical equipment. So, it is important to determine the type of charge:
- Battery. The main advantage is the lack of wires, so you can tidy up in all places and not worry about the length of the cord. Such models are compact and comfortable to use.
- Cigarette lighter. It has a high power rating, it can work for an unlimited time, ideal for general cleaning.
Some devices have a combined type of charging-such models are more functional.
Power is one of the most important parameters when choosing devices. As a rule, it varies in the range of 30-180 watts. The higher the score, the better, but here you need to take into account your goals and expectations. For example, 50-75 watts will be enough for easy cleaning and rare use. This is enough for light trash and dust. If you are very serious about cleanliness and often clean, give preference to devices with a capacity of more than 80 watts.
A bag or container can act as a dust collector. The second option is much more comfortable, since such elements are well removed and installed, and it is also easy to control its fullness.
It is not recommended to use models with a solid hose, as they can quickly break if temperature drops. Such elements must be durable and flexible. The length of the cord must be from 2 meters, then consider for what car you buy the vacuum cleaner . It is possible to buy car vacuum cleaner in Kiev, Kharkov, Odessa on 130.com.ua with delivery across Ukraine.
Materials on the topic
Car vacuum cleaners: Best Sellers
