TOP-3 2017 heated seat covers
In winter, traveling in a car can be a pain, because in the morning the car meets us with cold seats, frozen windows, a discharged battery and a layer of snow on the body. One of these problems will help cope seat heating. They will not let you freeze inside the car.
There are several types of seat heating-capes, seat covers and seat heatings built into the seat. Each of them has its own functional and operational features. This article contains the most popular heated cases for 2017.
Top heated seat covers-Comparison table:
1 place | 2 place | 3 place | |
Heating Control | is | is | is |
heating element | wire | wire | carbon fiber |
Number of covers included | 2 | 2 | 1 |
Advanced | Convenient power wiring | Convenient power wiring | Insulated steering wheel cover, extra accessory pocket |
![Car covers with heated Milex Arctic Dark Blue on the front seats with heat control color dark blue Car covers with heated Milex Arctic Dark Blue on the front seats with heat control color dark blue](/published/publicdata/AUTO/attachments/SC/products_pictures/Car-seat-covers-with-heat-function-Milex-Tango-Dark-Blue.jpg)
- ★ 2 covers included
- ★ Heating controller
- ★ Sits tightly on the seat
- ★ Convenient output power wire
- ★ Stylish dark blue color
![First place First place](/images/gold-medal.png)
Milex Arctic Dark Blue seat covers will help make cold winter trips cozier and more comfortable. 2 covers that are included in the kit, easily put on the driver and passenger seat. And due to the fact that the power wire from the covers is removed from different sides (the driver’s case is on the right, the passenger side is on the left), no wires will hang under your feet and interfere.
The heating element in these seat heatings is wire, which provides a good heat in a short time. But such an element of heating has its drawbacks. The main drawback is poor flexibility. With frequent bending of the cover, the heating element can be damaged and if it breaks, the heated seats will fail. But with careful use, if you do not crumple the case and during storage do not put heavy objects on it for a long time, then Milex heating will last more than one season.
The undoubted advantage of seat heating Milex is large, compared with other heated cases, the number of colors-black, red, dark blue, gray and light blue covers are available in the range. This season, the most popular were dark blue, and the second most popular were red covers.
It is also worth noting that the Milex heated covers are equipped with a heating controller, with which you can adjust the heating temperature for yourself. The device has 3 modes of operation-low heat, high heat and off mode.
Due to its affordable price and good performance, these heated covers deservedly occupied First place in the TOP.
- + 2 covers included;
- + Heating controller;
- + Sits tightly on the seat;
- + Convenient output power wire;
- + Stylish dark blue color.
- - Wire heating element.
![Car covers with heated Milex Arctic Red front seats with heat control color red Car covers with heated Milex Arctic Red front seats with heat control color red](/published/publicdata/AUTO/attachments/SC/products_pictures/Car-seat-covers-with-heat-function-Milex-Tango-Red.jpg)
![Second place Second place](/images/silver-medal.png)
Milex Arctic Red seat covers will help make cold winter trips more cozy and comfortable. 2 covers that are included in the kit, easily put on the driver and passenger seat. And due to the fact that the power wire from the covers is removed from different sides (the driver’s case is on the right, the passenger side is on the left), no wires will hang under your feet and interfere.
Due to its affordable price and good performance, these heated cases deservedly occupied Second place in TOP.
![Seat cover with heating HEYNER WarmComfort Pro 505600 with heat control and a warming cover on the steering wheel, color black Seat cover with heating HEYNER WarmComfort Pro 505600 with heat control and a warming cover on the steering wheel, color black](/published/publicdata/AUTO/attachments/SC/products_pictures/Heatable-seat-cover-Heyner-WarmComfort-Pro-505600.jpg)
Heated seat cover HEYNER WarmComfort Pro 505600
- ★ Carbon fiber heating element
- ★ Stylish design
- ★ Pleasant to the touch material
- ★ Warm steering wheel cover included
- ★ German quality
![Third place Third place](/images/bronze-medal.png)
German heating covers HEYNER have been famous for their quality and reliability for years. Upholstery material covers made of pleasant to the touch materials and the cover itself is generally made stylish, and looks expensive. The cover of HEYNER WarmComfort Pro 505600 is made in black color with silver inserts in the center. Thanks to this color, this case will look organic in the cabin of almost any car.
This heated seat cover is equipped with carbon fiber heating elements that provide high-quality heating and are one of the best heating elements. Unlike wire heaters, carbon fibers are less susceptible to deformation and are not afraid of frequent bends.
HEYNER heated cases have a regulator with 3 modes of operation-low heat, high heat and off mode. In addition, an additional heating cover on the steering wheel is included in the kit for these cases.
- + Carbon fiber heating element
- + Stylish design
- + Pleasant to the touch material
- + Warm steering wheel cover included
- + German quality
- - There is no separate cover on the passenger seat, when installing the cover on the passenger seat, the power cable is displayed on the right side
- - High cost.
In winter, it is highly recommended to use heated seats in the car, as a long stay in a cool seat can adversely affect the health of both the driver and the passenger. Heated covers are easy to use, put on the seat for a couple of minutes, connect to the cigarette lighter and immediately after that they are ready to go. It is possible to buy a cover with heating in Kiev, Kharkov, Odessa on 130.com.ua with delivery across Ukraine.
