TOP-5 car alarms. Rating of car alarms 2021!
Now it is difficult to imagine any car without a car alarm. After all, it will help not only to protect the car from theft, but also to warn the driver in time about the approach of a stranger to the car. Modern security systems have tremendous capabilities with a high level of protection. There are alarms with one-way or two-way communication, with GSM and/or GPS modules.
Manufacturers have also developed original technologies to protect their products from scanning attempts and code-grabbing. Therefore, when choosing an alarm, you should pay attention to the presence of an interactive or dynamic method of protection against scanning. Other interesting features include automatic start, Bluetooth, CAN and/or LIN interfaces, car search in the parking lot, and many others.
In order to choose a suitable alarm from a huge variety of models, we have selected the TOP-5 car alarms that are most popular among our customers. This TOP includes:
Pandora DXL 4710
The first and most expensive model of our TOP is Pandora DXL 4710 with dialogue protection. This is the most modern version of the security complex. Suitable for installation in most vehicles and supports 3xCAN and 2xLIN digital buses. The huge functionality of the system will not only reliably protect the car from theft, but also notify the owner of the location of the car. A Bluetooth interface with support for GSM modems provides the owner with full control over the security system using mobile applications, regardless of the distance.
Built-in GPS will allow you to control the location of the car in real time, and view the entire history of movements.
The IMMO-KEY interface allows to bypass the built-in immobilizer algorithmically without using a key. Thanks to this, the owner does not need to make a duplicate key.
Another advantage is the automatic start function. The owner can configure autostart by temperature, timer and other parameters. Additional protection in this model is the presence of a radio tag and a siren.
Package Contents:
- Control Unit
- Owner's card
- Label (2 pcs.)
- Cover for RFID tags
- Remote button
- Set of cables and fasteners
- Beeper
- Relay module
- Temperature sensor
- Siren
- Connection diagram
Pandora DX 40S
Next on our list is the Pandora DX 40S. This is a two-way alarm system with support for 2xCAN and Lin digital buses, as well as an immobilizer crawler. In this model, automatic start can be optionally added at any time after the alarm is set.
This alarm and all settings can be controlled using a remote control with an LCD display. Also, the key fob will notify about all security violations.
The main advantage of this model is its low power consumption, which is only 4.5 mA. Therefore, the battery will retain its charge for a long time, even if left for a long time in the parking lot.
Package Contents:
- Control Unit
- Button
- Cables DX90, DeLuxe, X1000
- Mounting kit
- Keychain
Pandora DX-57
Car alarm Pandora DX-57 is perfect for installation on budget cars. This is an inexpensive, simple, but effective solution for car protection. Despite its low cost, this system supports connection via CAN, LIN, IMMO/KEY-ports and other protocols, allowing it to be installed on most modern car brands. It was specially designed to replace the other low-cost version of the Pandora DX-50Sv2 alarm.
This security system is made taking into account the experience of more expensive models DX-6X, DX-9X and took the best from them: a wide range of security and service functions that enhance the capabilities of the vehicle; 16 security zones, there is even protection against theft of wheels; smart autostart of the engine; convenient pre-heating of the engine, etc.
Pandora DX-57 has a good package, which, despite the budget segment, guarantees a high level of car protection. The main difference from older models is the lack of a Bluetooth interface. In addition, it should be noted that the 868 MHz radio channel works with the economical Spirit2 transceivers. But they also work well, providing high anti-interference performance and good transmit/receive range. Even in a large city, the system will not give false positives and will not suffer from interference.
Package Contents:
- DX50S main unit
- Keychain LCD D011 black carabiner
- DX fasteners spare parts
- BS2 Button
- DX90 v2 IMMO Cable
- Relay module autostart RMD-5M
- Cable for analog temperature sensor L3000
- Key cable TM DeLuxe
- X1000 Main Cable
Sheriff ZX-1090
Sheriff ZX-1090-two-way alarm with auto start, working with rolling code. It provides the owner with such standard functions as passive and silent arming, anti-robbery mode, two-stage disarming, searching for a car in the parking lot, remote activation of the "Panic" mode.
9 security zones are monitored with bypass faults. Additional features include a turbo timer, separate opening of the driver's and passenger doors (the so-called "American type" central locking), calling the driver from the passenger compartment, etc. The alarm is equipped with four additional channels with flexible settings, to which you can connect power window control, trunk lock, etc.
There are outputs for blocking the engine and starter. The central locking control module is a power one, which eliminates the need to use additional relays. It is possible to connect an additional sensor, for example a microwave one (the so-called volume sensor). The main keychain is ergonomically shaped, with a shock-resistant antenna, and is equipped with an informative LCD screen.
Package Contents:
- Control Unit
- Blocking relay
- RF module (radio module)
- Two-way LCD keyfob
- Additional remote control without LCD indicator
- Shock sensor
daVINCI PHI-330 PRO
DaVINCI PHI-330 Pro is a two-way alarm system without autostart. It provides the owner with such standard functions as passive and silent arming, anti-robbery mode, two-stage disarming, and finding a car in the parking lot. It also allows for separate opening of the driver's and passenger doors (the so-called "American-style" central locking), engine support (turbo timer).
There are outputs for 3 additional channels (connecting power windows or their control module, trunk lock, "polite" lighting) and two engine blocks. The central locking control module is a power one, which eliminates the need to use additional relays. It is possible to connect an additional sensor, such as a microwave (so-called volume sensor).
The main key fob is equipped with an informative LCD screen and operates with a dialogue code at 868 MHz, which is highly resistant to burglary.
Package Contents:
- Control Module
- Two-way transceiver antenna with the function of making a call to the key fob ¬ transmitter with LED status indicator
- 5-button keyfob
- Transmitter with LCD display and feedback function
- 4-button transmitter with dynamic code
- Two-zone shock sensor
- Push-button switch "Valet"
- Blocking relay
- Instructions for use and installation
Related Materials
Car alarms: Best Sellers
