TOP-3 child car seats. Child car seat rating 2022
A child car seat is a special device for transporting children in a car. The main task of such a device is to ensure the safety of the child in the event of an accident, during emergency braking or during steep maneuvers. It reduces the likelihood of injury that can lead to death by as much as seventy-five percent. The main thing is to install the car seat correctly and be sure that it can save the life of the child and, moreover, is very comfortable.
You should approach the choice of a child car seat responsibly and familiarize yourself with the main aspects in choosing.
The first and most important thing is safety. You need to start with this criterion, and only then move on to the rest. It is not necessary to deal with all the nuances of the car seat device, the main thing is to check whether the desired model has a European safety certificate (this is evidenced by the ECE R44/03 or ECE R44/0 marks in the specification) or a mark on passing the ADAC crash test (an international German industrial laboratory that conducts the most hard tests). If there is neither one nor the other, the car seat may have a high rating in independent crash tests, an “excellent” rating at the end of the year is enough for 99% confidence.
Select a car seat according to the age, height and weight of the child, then it will provide maximum safety. There are several groups: 0+/1/2/3, each of which is designed for a certain age and weight of the child, there are universal models, for some or for all age groups at once.
The only reasonable way to save money on buying a car seat is to take a universal model from zero to 12 years old. They are modular, the cradle insert is replaced with an insert for a child up to 4 and so on. But the quality requirements for such chairs are much higher, because they must last 12 years without losing their appearance.
The easiest car seats to take care of are the ones that come with a removable cover. This makes it easier to wash or air out.
If you have an old or retro car, choose seat models with a regular seat belt. They are universal and will fit any vehicle. Most modern cars are equipped with IsoFix connectors to which the car seat is attached. This method of fastening is more reliable, more convenient, it allows you to quickly install and dismantle the chair.
Choose car seats that are easy for everyone to carry. Not only to an adult strong man, but also to a girl, a teenager, the elderly.
Sustainable materials are preferable, but synthetics are better than natural fabrics, as they are more durable and withstand more washes.
It is better to choose elastic belts with which a child is fastened in a car seat, with intuitive latches. This is important so that in a critical situation you can quickly remove the crumbs from the car.
Seals that protect and support the baby's head are best taken with ventilation holes. So the child will sweat less.
And now we have selected for you the TOP 3 child car seats that are most popular among our customers. Here is what the TOP consists of:
- Britax-Romer TRIFIX2 i-SIZE Grey Marble
- Britax-Romer DUALFIX i-SIZE Cosmos Black
- Britax-Romer KIDFIX2 R Storm Grey
Britax-Romer TRIFIX2 i-SIZE Gray Marble
The TRIFIX2 i-SIZE Gray Marble car seat is the perfect replacement for a car seat. The design of this model is very carefully thought out to make the transportation of children aged 15 months to 4 years as comfortable and safe as possible. The car seat is ideal for toddlers between 76cm and 105cm tall. By using only the latest innovative safety features in this child seat, you don't have to worry about your child being poorly protected. The chair provides a high level of protection in all types of collisions.
Separately, it must be said that these chairs have successfully passed the test of the famous German automobile club ADAC. As a result of the tests, they were awarded a rating of 2.1 "GOOD" (ADAC Motorwelt 06/2018). A very good result, confirming the high quality and excellent level of protection.
Child car seats of this series provide comprehensive safety for small passengers. For this, several important protective systems are provided. In such a seat, the baby is literally in a cocoon well protected from all sides. In addition, since the side walls have a very soft upholstery, the child will sit in it very comfortably. This is a great option for trips around the city and long-distance country trips.
Thanks to the use of a special Top Tether anchor strap and an integrated ISOFIX system, these car seats are very easy to install. It only takes a few minutes to fix. Please note that it is suitable for all i-Size car seats and seats with ISOFIX attachment points, so the seat is suitable for a wide range of vehicle brands.
The car seat has soft upholstery, and due to the increased sidewalls, it reduces the risk of injury to the child in case of a strong impact. The sidewalls create a protective barrier that simply absorbs the force of impact, minimizing its impact on the fragile body of the child.
Integrated 5-point harness has extra padding. They are ergonomically shaped and made of durable material. Thanks to them, comfort is increased, since the belt tightly holds the child in the chair, the pads do not allow him to press hard, smoothing out the impact. Like the cover, they are easily removed and can be washed in the washing machine.
The child seat has an integrated SICT inside system-a modern technology that is designed to guarantee a high level of protection against side impacts. The principle of its operation is that the system is able to absorb the force of impact, therefore, in the event of a collision, it extinguishes the energy, minimizing the likelihood of a child getting head and neck injuries.
In the event of an accident, additional protection is provided by specially developed proprietary technology that prevents rollover. In a collision, it first directs the force down towards the car seat, and then forward. This provides protection against injury to the head and neck.
The Britax Romer DUALFIX i-SIZE Cosmos Black child car seat is suitable for transporting children from birth to 4 years old, weighing from 0 to 18 kg. The main feature of this model is that the chair can rotate 360 degrees. This increases the comfort of its use, since, if necessary, you can install the seat both against the direction of travel (recommended for the smallest passengers) and in the direction of travel (this option is used when the child grows up a little).
It is also worth noting the original design and high quality of Britax Romer car seats. All elements are strong and durable, the material is soft, does not cause allergies when in contact with delicate baby skin. The model was tested by the reputable German automobile club ADAC and received a rating of 2.1 "GOOD" (ADAC Motorwelt 06/2018). This is a fairly high figure, confirming the reliability and safety of child seats in this series.
The car seat is rated (0/0+/I) so it is guaranteed to provide the same safety and comfort for both infants and 4 year olds. Maximum comfort can be achieved thanks to the flexible position adjustment system. This chair can take one of 12 positions, including a completely horizontal position, so that newborns can lie down and not strain their back muscles. For them, this is the most natural position. With such a chair for children, even very long trips will be comfortable.
The main task of the child seat is to ensure the safety of the child while driving. This series meets the requirements of the latest safety standard ECE R129 (i-Size). These car seats are equipped with many innovative systems designed to maximize protection. For example, they have a unique SICT inside system, which guarantees the safety of the child in the seat in case of strong side impacts. High quality is confirmed by many crash tests and relevant certificates. In such a chair, the baby will feel comfortable and safe.
All Britax-Romer products are manufactured in Germany using high-quality European equipment. Strict control is carried out at all stages of production. The company sets its own standards, which are tougher than the norms established by law. In addition, child seats are constantly tested and crash tested, their reliability and high level of protection are confirmed by international certificates.
This car seat can rotate 360 degrees around its axis. This allows you to choose the optimal position, turn the child facing forward or backward. If necessary, it easily turns sideways to the open car door, which makes it easier to get in and fasten the baby. After the child is fixed, the seat unfolds and can be installed in any position convenient for the trip.
These seats have an innovative built-in SICT inside system, which contributes to the maximum degree of protection in a side collision. The technology is specially designed to absorb impact energy and reliably protect the child sitting in the chair. Moreover, nothing needs to be adjusted or configured, the peculiarity of this technology is that it is already ready and guarantees the protection of a small passenger.
The kit includes an additional insert for newborns, which has special removable shock-absorbing pads. It is necessary so that even the smallest passenger feels comfortable during the trip. The shape of the insert is specially designed to provide support to the back while guaranteeing a comfortable and natural position for the child in the seat when they are lying down.
The Britax KIDFIX2 R Storm Gray baby car seat is an excellent 2 in 1 model, it has an original design and excellent performance. This model was created on the basis of the popular line of armchairs of this brand KIDFIX. It is designed to transport children aged 3.5 to 12 years. As the child grows, the backrest and headrest can be adjusted to provide optimal conditions and a sufficient level of protection.
The main feature of the updated chair is the removable backrest. If the child is tall-more than 135 cm, then you can remove the backrest, providing the child with more space. At the same time, thanks to the presence of a special SecureGuard system, you can securely fix the child, providing the necessary level of security.
Thanks to the high back of the chairs of this series, on the one hand, they provide comfort, on the other hand, they protect well from impacts. Padded sidewalls and an adjustable headrest ensure full body protection from head to hips. With such a seat, any trip will pass in a pleasant atmosphere. The special V-shaped backrest will guarantee a comfortable seating of the child in the chair, even if it grows and becomes wider in the shoulders. We can say that the chair grows with it. It will appeal to both toddlers and older children, as it has a carefully thought-out design.
The chair has a special system that allows you to position the seat belt so that it holds firmly, but does not press. The belt will be above the bones of the pelvis, this is very important, as it helps to avoid possible injuries in the abdomen in the event of a collision. The belt is fixed with the help of special guides, as a result, it is possible to get the correct position diagonally above the shoulder if you decide to use a chair without a back.
Since this model is designed, developed and manufactured in Germany, the chair is of very high quality and reliability. The company constantly conducts specialized factory tests using the most modern equipment. Both options (with and without a back) showed excellent results. I must also say that Britax Romer specialists constantly monitor all the developments that appear in the automotive industry, this allows them to modernize their child seats in a timely manner and make them as safe as possible.
The seat provides three levels of passenger protection thanks to the special backrest design. In particular, it has: wide sidewalls that provide reliable protection for the entire body; soft headrest that allows you to protect your head and neck in case of impact; as well as upper and lower guides, used to ensure that the seat belt is optimally positioned for the child.
SecureGuard technology, which is used in these car seats, provides an additional attachment point in the standard three-point belt. It acts as a protection for the abdominal area. This technology makes it possible to reduce the force of impact on the child by about a third in a head-on collision. That is, the most vulnerable area-the stomach, receives additional protection, which is very important. Moreover, this does not affect the comfort of the child and does not hinder his movements while riding in the car.
Related content
Baby car seats and boosters: Best Sellers
