Ланцюги протиковзання
Close
TOP-3 car vacuum cleaners. Rating of car vacuum cleaners 2022
A car vacuum cleaner should be in the car of every motorist who loves cleanliness and order in the cabin. Car vacuum cleaners will not only keep the interior clean, but also save money on cleaning the interior at the sink. A vacuum cleaner for cars is much more compact than a household vacuum cleaner and more convenient to use. When choosing a car vacuum cleaner, you should pay attention to the following parameters.
Power
Really powerful and most efficient models are considered where this parameter varies from 100 to about 160 watts. An average value in the range of 60-90 W is usually enough for simple, high-quality cleaning. But car vacuum cleaners with lower rates (most often battery-powered) are almost useless. Leading manufacturers additionally indicate the so-called suction power in watts or kPa for their models.
It is important to understand that it is pointless to evaluate the power of a portable vacuum cleaner for cars in comparison with professional "monsters" for car washes and home models. The car network supports 12 volts, not 220 volts, and its capabilities are limited.
Type of cleaning
The bulk of car vacuum cleaners are designed for dry cleaning. Do not look for washing models. If wet cleaning is indicated, in this type of appliance it usually consists in the ability to collect a certain amount of liquid. That is, you wash the stain with detergent manually, and then remove the wet foam with a vacuum cleaner. Even single specimens are capable of drawing in liquid dirt from rugs in large quantities without consequences that are critical for performance.
Price
Usually, the more expensive the vacuum cleaner, the more powerful it is and the more functions it has, however, in some cases, the cost is extremely high due to the brand.
Food
There are three options for connecting car vacuum cleaners: a 220-volt network (usually used for recharging), a built-in battery (an important indicator is battery life), a 12-volt car network (the length of the cigarette lighter cable should be taken into account). The latter option is the most common and effective in terms of maintaining the power of the vacuum cleaner. Especially if you start the engine during the cleaning process.
Complete set
The presence of a variety of nozzles and accessories allows you to perform different types of cleaning.
So that you do not suffer with the choice of a suitable model, we have selected for you the TOP car vacuum cleaners that 130.com.ua customers choose. These are really high-quality models that have proven themselves well. So, here is our TOP:
HEYNER CyclonicPower PRO 240
The powerful Heyner CyclonicPower PRO 240 car vacuum cleaner is designed for dry and wet cleaning. This is a model from a well-known brand from Germany, which specializes in the production of premium quality car accessories. The power of the device is 135 watts. Such a vacuum cleaner will become a reliable assistant in maintaining cleanliness and order in the interior of your car.
The body of the device is made of durable plastic, it has an on/off switch, as well as a special button with which you can detach the dust container. There is also an LED backlight that makes cleaning comfortable even in those hard-to-reach places where the illumination is very low. It can run continuously for up to 30 minutes (longer runs may unnecessarily drain your car battery).
The unique filtration system prevents the filter from clogging, so the car vacuum cleaner maintains suction power, regardless of the degree of debris filling.
Double cone filtration system, powered by modern centrifugal technology, captures the smallest dust particles. Visual control over the degree of filling of the vacuum cleaner container can be carried out thanks to a transparent flask. Please note that the filters are removable and can be used repeatedly. You just need to wash them and install them back.
This model is suitable for both dry and wet cleaning of the car interior and trunk. With it, you can even collect spilled liquid. For example, it can be used to collect water that remains on rubber mats after snow melts. To carry out wet cleaning of the interior, it is necessary to apply a soapy solution to the places of contamination and vacuum thoroughly. You can not worry about the fact that water will get into the motor of the car vacuum cleaner-the cutter, which is located in the path of the air flow, will not allow it to penetrate there.
The capacity of the dust collector in this vacuum cleaner is increased and is 350 ml, and the moisture capacity is 100 ml.
The vacuum cleaner has all the necessary attachments for all types of cleaning. For example, a flat crevice nozzle allows you to remove debris in the most inaccessible places, because a huge amount of dust and debris often accumulates between the seats in the cabin. There is also a special round brush included in the kit, which easily cleans the surface of the seat from pile and wool. There is also an additional nozzle for cleaning on flat surfaces and an adapter for nozzles.
The vacuum cleaner is connected to the car's on-board network through the cigarette lighter socket. The length of the cord is 4 meters, which is enough to make cleaning comfortable not only in the cabin, but even in the trunk.
Complete set:
  • Vacuum cleaner
  • Network cable with cigarette lighter adapter
  • Crevice flat nozzle, round brush, flat surface nozzle
  • Storage bag
  • Manual/warranty card.
VOIN VL-330
Car vacuum cleaners: Best Sellers
