Modern gasoline generators — classification, purpose, features of operation
Gasoline power plants are used as sources of autonomous and backup power supply. They are great for use in any weather and at any time of the year. Gasoline models are often preferred because they are easy to operate, economical and highly productive. They work on ordinary gasoline, which is very easy to get everywhere.
A modern gas generator, depending on its capacity, can maintain the performance of both household appliances in a private house and a small production for a long time. Manufacturers now offer a lot of different models, which differ among themselves in many ways and are intended for different purposes. Therefore, it is very important to decide before buying what exactly is right for you. To better understand the features and capabilities of electric generators of this type, let's take a closer look at the principle of their operation, the types of devices and the specifics of operation.
Working Principle
The design of all gasoline generators is quite simple. They are a system that combines a device generating an electric current with an internal combustion engine, into the cylinders of which a gasoline-based air-fuel mixture is fed. The mixture during the operation of the unit inside the engine gradually burns and transmits the torque to the shafts of the power plant, which generate electrical energy.
This design is characterized by stable performance and reliability, allows to obtain a fairly high efficiency. On average, the power of such units can reach from 100 W to 15 kW. This is a very important parameter to consider. If higher power is required, then most likely it would be better to purchase a diesel unit.
Generator Classification
Despite the fact that the overall design of all gasoline power plants is very similar, yet different models can vary greatly in a number of important parameters. The main ones are: type of engine starting system, engine type and phase.
By startup type
- manual;
- electric;
- automatic;
- with a remote start.
By type of engine
- Two-stroke. This variety is not very powerful & ndash; up to 1 kW. They are not suitable for continuous use. It is best to use two-stroke engines as emergency power sources or to periodically feed individual energy-consuming devices.
- Four-stroke. This version unlike the first demonstrates high reliability. They are great for long term use. They are able to produce more power, generate a stable flow of energy, so they can act as a constant current source. However, they have some drawback, such installations need more fuel. Consequently, the cost of their work will be more.
By phase
- Single phase. They are suitable for providing power to equipment that is powered from a 220V network. They are the optimal choice for powering household equipment and electronics. Such installations are preferable to install in country houses, offices, shops, etc. The power of such plants rarely exceeds 10 kW.
- Three phase. Their difference is that in addition to the voltage of 220 V, they are able to produce a current with a voltage of 380 V. Typically, the case has a special switch that allows you to adjust the mode of operation. They are recommended to be used in production when it is necessary to ensure the work of professional three-phase equipment. For home and household tasks are rarely used.
Applications of autonomous gasoline power plants
Now electric generators are used everywhere in a wide variety of industries: on construction sites, in agriculture, in country houses, in warehouses and in factory workshops. They can be used as seasonal, permanent and backup power supply of a wide variety of devices and other consumers. Gasoline generators can ensure the functioning of the lighting system, maintain the operability of power tools, household appliances, heating appliances, etc.
Scope of application is largely determined by the capacity of the installation. Here you can highlight the following recommendations:
- 1-3 kW — these generators are suitable for installation in small street points of sale.
- 4-6 kW — can be used to provide power to compressor installations, power tools, welding machines, pumps and other similar equipment.
- 5-10 kW — units of this power are the best option for country houses, medical facilities, shops, offices, etc.
- 8-15 kW — these are the most powerful installations that can cope with a large load, they are recommended to be installed on the production, construction sites and other facilities where there are a lot of appliances and equipment consuming a lot of electricity.
Advantages of generators of this type
Modern gasoline power is a reliable device that allows you to get independent power supply at any time. Due to the design features and the use of advanced technologies, this type has many advantages:
- high performance and efficiency with compact dimensions;
- relatively low fuel consumption;
- long life;
- low reproducible noise;
- a wide range of operating temperatures, they continue to function even in severe frost.
All this, together with a reasonable price, makes gasoline-powered electric generators popular and in demand. It is they who are given very many citizens when they choose an installation for a dacha or a private house.
If you are looking for a reliable, practical and powerful source of backup power, you can always choose the right model and buy a gasoline generator with delivery to Kyiv, Kharkov, Odessa at 130.com.ua. In our online store there is always a large selection of models from leading manufacturers.
Related materials:
Generators: Best Sellers
