Two-way alarms for auto-budget class
Cost * - from 1000 UAH.
Signaling daVINCI PHI-300, PHI-330, as well as PHI-310, PHI-320, PHI-499 and PHI-350 Dialog - security systems of budgetary level. These two-way alarms are interesting in that they have an excellent price-functional ratio. With a small cost of signaling, daVINCI has many functions that are not available even in more expensive models.
Standard set of security functions: protection of doors, hood, trunk; shock sensor to protect against breaking glass car; possibility to organize two chains of engine blocking (although many other systems have only one line for blocking the engine).
Additional functions, which are often absent in budget security systems: passive immobilizer function, anti-robbery function; it is convenient to implement the silent arming by holding one button (many systems need to consistently press two buttons).
See video reviews of car alarms:
Implemented the function of arming without a key fob, - the machine becomes armed using the service button VALET with the subsequent exit from the car and slamming the doors. This is necessary if a battery has been installed in the key ring, which can not be replaced at the moment, or the owner leaves the car in a place where there is a suspicion of intercepting the signal by a code grabber (an electronic "master key" for breaking alarms and then penetrating the car's interior). Also, the removal of the guard without a key fob has been realized by opening the car door, turning on the ignition switch and the VALET button by a certain procedure.
Another interesting anti-theft function - in a hidden place you can put a toggle switch, when enabled, the alarm activates the engine lock and this lock can not be disabled either with the keyfob or with the service button VALET.
Dynamic code systems (except for the PHI-350 Dialog), that is, each time the system is armed / disarmed, the code is modified - this makes it difficult to use ordinary, primitive code-grabbers. The data exchange of the car alarm with key fobs occurs at a frequency of 433 MHz.
Liquid Crystal Keychains daVINCI alarms are not bulky, have average dimensions and convenient arrangement of buttons. It should be noted that on the key fobs daVINCI PHI-300, PHI-330 and PHI-350 Dialog for fastening to the keys there is a metal eye that is Part of the case and it will not break out for a long time, unlike many other systems where a carabiner is attached often breaks off. On the key fobs of these models, the buttons are locked.
The above mentioned advantages are possessed by car alarm daVINCI PHI-350 Dialog. It is worth noting two main distinguishing features - the presence of two key fobs with LCD display and a more powerful dialogue algorithm for data exchange (compared to the dynamic code of other models daVINCI). The presence of a dialogue code and an additional full-fledged LCD key fob from daVINCI PHI-350 Dialog may become decisive factors when choosing a budget car security system.
Installation. DaVINCI alarms are convenient and easy to install, which can be performed by specialists with initial qualifications. The central alarm unit is very compact in size - it allows you to install it in any convenient hidden place. Despite the fact that the unit is compact, it has power outputs to the central locks and turn signal indicators repeaters - this is an undoubted plus. The systems have a well-designed shock sensor, uncritical to the location - it will in any case be sensitive. In daVINCI systems, a fairly clear programming of functions is enough. Data alarms can be recommended for installation on budget models of cars. If there are valuable things in the car, then it is better not to save on signaling in the car. Buy bidirectional alarm in Odessa, Kharkov and Kiev can be on 130.com.ua delivery in Ukraine.
Cost on 130.com.ua
Related materials
Car alarm Sheriff ZX-750PROBuy4427 ₴ -
Car alarm Sheriff ZX-1095PROBuy5075 ₴ 4156 ₴ -
Car alarm Cyclone X-1000Buy2899 ₴ -
Car alarm Cyclone X-470DBuy2849 ₴
