Sound insulation VW ID Unyx
Door installation kit and diagram
Materials
| Material | Count |
| Vibration isolation ACOUSTICS ELECTRO 1,5 mm, 700×500 | 5 шт |
| Vibration isolation MULTISOFT 6 mm, 700×500 | 4 шт |
| Sound-absorbing material SoundWave 15, 500×1000 | 2 шт |
| Sound-absorbing material SoundWave PRO 15, 750×1000 | 2 шт |
Cutting sheets — on site
Where to install
External door panel
Vibration isolation- ACOUSTICS ELECTRO — pieces of metal, rolling with a roller.
- MULTISOFT 6 mm — on top of the vibro, also in pieces (do not cover the drains).
Closers/rods are mounted on top of the vibration.
Door cards — front
Vibration isolation- ACOUSTICS ELECTRO — local spots (patches).
- SoundWave PRO 15 — solid sheet on the map.
Door cards — rear
- SoundWave 15 — solid sheet.
Front door — disassembly
Rear door — disassembly
Example of laying vibration/noise insulation
Short process
- 1 Remove the cards, degrease the metal, check the drains.
- 2 Stick ELECTRO vibration pads onto the outer door panel (in pieces) and press down firmly.
- 3 Place MULTISOFT 6 mm (in pieces) on top, do not cover service areas.
- 4 On the cards: vibration pads + noise protection sheet (front — PRO 15, rear — 15).
- 5 Assembly, checking the operation of closers and the absence of squeaks.
