We make noise isolation of the car with our own hands
Noise isolation auto - a way to make a quiet interior by eliminating any extraneous sounds, including squeaks and noises. Good factory noise insulation is present except in luxury cars. The rest have to carry out this procedure on their own.
There are several reasons for installing noise insulation. For example, it's trite, but to reduce noise or improve the sound of the speaker system. Even if you have an inexpensive tape recorder installed, the sound quality can improve significantly with the installation of noise insulation.
Depending on the chosen goal, you must select the material. After all, it is also vibroizolyatsionnym, anti-scribe.
Noise isolation by one's own hands: what you need
If you have a limited budget, it is better to make noise gradually. Buy quality material, but glue the body parts. For example, this month to make doors, and next - the hood. The quality of the raw materials will depend on the result.
For installation work you will need:
- — Building hair dryer. Do not even think of using the usual one. It is important to use a special tool.
- — Rolling roller. It is necessary in order to reliably roll noise to the body. It is inexpensive, but the benefits of it a lot.
- — Scissors to prepare sheets of the desired shape and size.
- — Degreaser is an obligatory stage of surface preparation for subsequent work.
Before you start, read all the nuances of your body. In advance, calculate the required material. First - all the preparatory work, then - the main process.
Noise isolation of the hood
Drivers believe that pasting the hood, you can forever forget about the noise of the engine. But this is a big mistake. Yes, you can reduce extraneous sounds, but completely get rid of them will not work.
The noise insulation of the hood more helps to improve the insulation, which is especially important during the frost period. To do this, suitable materials: vibroplast silver and accent 10 mm. If you still decided on the noise, then first you need to pick up the material by weight. After all, do not forget that you can not heavily weight the hood, otherwise shock absorbers can flow.
Note that noise is the initial and base stage, and vibration and heat insulation is already an addition.
Sound insulation of doors
Doors are glued to noise to exclude most of the extraneous sounds and greatly improve the sound of music. It is also necessary to pay attention to the weight of the material, since with a strong weighting, you will have to change the hinges more often.
Here everything is simple: the larger the area will be covered with vibration isolation, the better effect you will achieve. To improve the sound, the noise insulation is made in 4 layers.
Roof Soundproofing
The roof is glued to reduce the noise from precipitation. After carrying out noise insulation, the rain will no longer produce such a loud noise. Often drivers save and leave the roof uncoated. However, in order to obtain the maximum effect, it is better to establish noise over time and to the ceiling.
Buy noise insulation for cars in Kiev, Kharkov, Odessa can be on 130.com.ua delivery in Ukraine.
Floor insulation
The floor is glued with noise to get rid of extraneous sounds due to stone strikes on the bottom. You can use additional vibration isolation material. Especially pay attention to the arches of the wheels. For better effect, glue them with 2-3 layers of material.
Noise insulation: Best Sellers
