Noise isolation cars-for those who love comfort
"There is no limit to perfection"-it is under this motto many car owners are trying to improve the characteristics of the car, increase the power and efficiency of the parameters, increase the comfort of movement and refine the interior. Car noise reduction is one of the necessary processes for tuning your car, which reduces the level of noise penetration into the passenger compartment and, thus, increases comfort. The main source of noise is the motor, but the sound penetrates from everywhere-from the arches of the wheels, the bottom, the tailgate and, of course, from the large crevices and poorly assembled elements. In addition, extraneous sounds generate headwinds and friction of tires with a road surface. In all respects, it is reasonable to weigh all the pros and cons of any process. For this, in the first place, we would like to announce the possibilities that you will achieve after sound insulation of a car.
Advantages of car noise insulation:
1. Acoustic comfort.
- Improved acoustics. Due to the sealing of metal and vibration isolation, the sound does not walk and even inexpensive acoustics gives a decent sound.
- Reducing extraneous noise. You no longer have to raise your voice when talking while driving, and you will notice the difference between open and closed windows while driving.
2. Passive safety.
3. Comfort in the cabin. Comfortable lounge plays a significant role in the operation of the machine. So, after a high-quality sound insulation, the vibration load of the car decreases, a heat-insulating effect appears.
It so happened that manufacturers, even the generally recognized quiet luxury brands, make little effort to ensure sound insulation of cars and therefore it is necessary to make changes on their own. We suggest to sort out in detail what kind of noise insulation there are and about the nuances of the process.
Works on noise absorption can be complex and partial, which, in turn, are divided into such tasks:
- Noise isolation wheel arches. They do not create much noise, but transmit vibrations to other areas, which, as a result, develops into noise.
- Noise isolation luggage. Despite the fact that the trunk-this is not the car's interior, but another additional source of squeaks and buzz that affects the noise atmosphere in the car.
- Soundproofing car doors. This site passes a lot of external noise and therefore plays an important role on the general background. Especially important for the transport, where the dynamics of the audio system are installed at the door, because the sound quality after noise insulation increases significantly.
- Soundproofing hood. This zone delivers significant noise and vibration, and therefore relevant to all vehicles. Properly performed work makes the sound picture much more pleasant.
- Noise insulation roof. The ceiling can be a source of additional hum, when at high speeds air flows over the car and create additional sound, which makes this zone desirable for sound insulation.
- Soundproofing floor. It is obvious that the close proximity to the source of noise, relates this part to the list of zones that need to be processed first.
Properly selected material and its quality is the key to success and effectiveness of noise insulation of the machine. Experts say that it is impossible to achieve the desired result using one type in all places. This statement is based on the fact that each section has a different vibration and sound load, surface and task. Thus, the soundproofing material for a car can differ in composition, thickness and structure, and these types are distinguished: vibration dampers (vibration-absorbing), sound insulators and anti-cryptic. It is worth noting that in this matter, more layers of noise insulation material does not mean better. For each particular site, it is worth choosing the best option, which will fulfill its task, but will not critically weight the finished part. In addition to vibration and noise absorption, you can choose an environmentally friendly, easy-to-install material with anti-corrosion and sealing properties.
Of course, after selecting the noise insulators, you will face the question of installation. There are two options-do it yourself or contact the experts. In order to save money, you can do the work on your own, but we strongly recommend that you familiarize yourself with the process of soundproofing a car with your own hands in detail. Start work only when you accurately understand the principles of work and technology procedures in accordance with the brand and model of your vehicle. The main problem encountered when performing noise isolation is a neat disassembly of the cabin without broken parts and, more importantly, proper assembly.
As you can see, a simple noise isolation of a car turns into a rather complex process that requires a weighted approach and taking into account the maximum subtleties. In order to achieve the best result in the task, the modern market offers a wide range of highly efficient materials and a wide range of prices. you can buy materials for soundproofing a car on site 130.com.ua with delivery to Kiev, Odessa, Kharkov and in Ukraine.
Materials on the topic
Noise insulation: Best Sellers
