Recommendations for choosing noise insulation
Cars do not always meet our demands for peace and quiet, so drivers are increasingly coming to the question of choosing the right sound insulation. This process involves isolating the cabin from various noises, sounds and squeaks. To achieve this goal, several materials are needed. And in order to get a complete noiseless car, you need to not only buy it, but also install it correctly.
Today the car market offers these types of materials:
- noise absorbing;
- vibration isolation;
- antiskripnye;
- liquid for external sound insulation.
Each of them performs its function: removes noise, vibration or creaking.
Sound-absorbing materials
This category includes materials that absorb sound waves from the external environment. Thus, your salon is isolated from other sounds: you enjoy the sound of your favorite music or you can talk quietly with your interlocutor, without trying to shout down noise.
In most cases, such noise absorbers are used:
- Bitoplast is a practical option for insulation that can also be used to isolate from squeaking. It features high quality due to its individual structure.
- Accent-a material that is equipped not only with noise absorbing properties, but also with the possibility of thermal insulation and sound reflection.
All materials are soft structures with up to 95% absorption.
Vibration isolation of a car
Such materials reduce the level of vibration emanating from plastic and metal coatings. Their main difference is in viscoelasticity, which is inherent in all models of vibration isolation. This property is obtained through the use of bitumen or foamed rubber.
One of the most popular options is VibroPlast, which differs in its thickness. It is easy to install and also has one of the lowest mechanical loss factors. However, it is not recommended for metal surfaces.
Scraper Materials
Such materials are designed to eliminate the squeak that occurs during the contact of metal and plastic elements of the car. This stage of sound insulation is optional, but it will significantly increase the level of silence in the car. In most cases, this material is self-adhesive and waterproof. One of these materials is Butyplast Antiskrip sealing tape
Recommendations for the correct noise isolation of a car
Often this process begins with the hood and its cover. Here it is a mistake to assume that after noise isolation you can forget about the engine noise. This procedure is designed for thermal insulation of the motor in negative weather. You need to pay attention to the weight of the material itself, because if you heavily weight the hood, you will soon have to replace the shock absorbers.
Noise isolation doors is designed to get rid of external sounds, thus allowing better to hear interlocutors and music. For minimal protection, you can do without sound insulation, and if you want to add vibration isolation. Here you also need to take into account the weight of the material, because if the doors are heavily weighted, then it will sag over time and you will need to change the hinges.
Noise insulation of the roof and ceiling is done in order to get rid of the noise of rain and strong wind. So, after such a procedure, you will not hear a drumbeat during a heavy downpour. Of course, there will be muffled blows, but they will not disturb the comfort of the trip.
Noise insulation of the floor is designed to get rid of road noise, strikes against pebbles, etc. It is recommended to take a material of smaller thickness and, if necessary, make several layers. In places of wheel arches in the cabin it is better to add an additional layer. Noise Isolation buy with delivery in Ukraine to Kharkov, Kiev, Odessa at 130.com.ua.
Materials on the topic
Noise insulation: Best Sellers
