Seat Heaters Guidelines
If you feel the difference between an icy seat and a warm one, then installing a heated seat will only be a practical option for you. Imagine how cold it will be in the cabin of a car that has stood in the cold all day: you need to wait until it warms up and only after that go on business.
It's all bearable, if you have the time and mood to “dance” around the car, however, what if you overslept today, and you had to take an office chair 10 minutes ago? Or your daughter has an important exam for which you have no right to be late, but today you wanted to sleep five minutes longer. Familiar situations? Probably in this case do not really want to wait for the heating of the cabin, so that at least in a more or less warm car will go on business.
There is a way out-buy heated seats for cars, both for the front and for the rear: it all depends on your desires and budget possibilities. The first problem faced by any person who decides to choose such a structure is the choice: which model to purchase from such a wide range. To begin with, let's look at the main aspects of the choice.
Types of seats: their advantages and design features
Our main task is to help you choose a quality device that can last as long as possible with maximum efficiency. To begin, consider 3 general groups of types of heating:
- Embedded-may be an additional option from the manufacturer (found on new models, mainly luxury). If there is none, then we buy a separate heating system, which is installed directly into the seats. The main advantages are improved moisture protection, additional functionality and several temperature levels.
- Cape-a more affordable option, because it does not require special installation: it is enough to install the structure on the back of the seat with the help of special mounts and remove it if necessary. The main features are improved mobility, compactness and functionality.
- Case-if you compare the covers and heated capes, the capes often slip from the seat with frequent use, as they do not have a rigid attachment. In addition, seat covers look much more aesthetic than capes.
Please note that all three types differ only in the type and complexity of installation, and the functionality depends on the model itself.
Also, seat heating is chosen according to the type of heaters:
- Wire-in its functional features are very similar to the structures that are installed in the electric stove. The difference is that the wire itself is a bit thinner. To improve safety and increase the life of the heating element itself is covered with Teflon insulation.
- Carbon fiber-special polymer filaments made of carbon. They have a fast heating rate, improved flexibility and improved moisture resistance.
Modern models are equipped with an additional temperature control feature, so you can always go on trips with maximum comfort.
What to look for before buying
Each model of the heating system differs in its functional features, so during the selection, consider the following nuances:
- Overheating protection-found in almost every model. After turning on the system, the seat begins to heat up to a certain temperature, and then either goes into maintenance mode or turns off.
- Moisture: Of course, you should avoid getting moisture on the seat, but if this happens, your design will not sparkle, it will not break. After all, heating elements are reliably protected, besides, some models provide a system of protection against moisture.
- The maximum temperature can be 65 degrees, but in practice you will need 40 degrees for a comfortable and warm ride.
heated seats in Kharkov, Odessa, Kiev with delivery in Ukraine at an affordable price in the online store 130 .com.ua. The company's catalog includes a wide range of products, all the necessary information regarding the goods: everyone will be able to choose the ideal option for themselves.
Materials on the topic
Seat warmers: Best Sellers
