Car Pioneer with Karaoke - novelties 2017
Pioneer 2019 Products
Traditionally, in late 2017 Pioneer represents a new generation of head units and digital media receivers of the 2018 line. One of the main innovations was the function of karaoke. According to statistics, 29% of drivers sing in the car. During singing, they experience a spiritual and physical uplift, entertain themselves in this way in traffic jams.
So, three new models support the possibility of karaoke - DEH-S3000BT, DEH-S5000BT and MVH-S300BT.
In addition, the possibilities for connecting smartphones have been expanded: via Bluetooth, a module with the HFP protocol 1. (improved frequency range), USB Auto Pairing, wireless search for songs on the iPhone.
The official Pioneer ARC application is now available not only on iOS, but also for Android. Now you can also play music from other applications. Added additional low-frequency oscillations in the audio signal, you can independently adjust the sound with an equalizer with 13 bands.
Pioneer DEH-S100UB
Radio PlayerPioneer DEH-S100UB is designed to listen to music from FM radio stations, CD- disks, smartphones and other devices connected via USB or Aux.
Equipped with a Mosfet amplifier for better sounding of music at high volume. The model is pleased with the powerful functionality:
- Backlit screen with timer and the ability to adjust the brightness.
- Play music in random order.
- Ways of connection: AUX-output, regular steering buttons, USB.
- High and low frequency filters.
- Removable front panel.
The buttons are illuminated in red. Mounting size standard - 1 DIN.
Pioneer DEH-S100UBB
Pioneer DEH-S100UBB — This car CD-receiver with the ability to listen to music on smartphones with the operating system Android. High sound quality even at high volume provides a built-in power amplifier with parameters in 4x50 watts. For self-adjusting the sound there is an equalizer with five bands.
The difference from the DEH-S100UB in the backlight color, which is blue here. You can control the device using a special application on your phone.
Pioneer DEH-S100UBG
Pioneer DEH-S100UBG — The car receiver with built-in power amplifier will immerse you in an atmosphere of high-quality sound. The model supports WAV and FLAC formats. If you want to customize the sound yourself - at your disposal 5-band graphic equalizer and high / low pass filters.
It differs from the models of the same series (DEH-S100UB and DEH-S100UBB) with the highlight color, here it is green.
Pioneer DEH-S100UBA
Car stereo Pioneer DEH-S100UBA allows you to plunge into the atmosphere of your favorite music even on the road. There is an RDS function - a system for sending text messages over the radio. Advanced Android functions - not only music playback, but also charging the smartphone battery. Energy saving mode implemented.
The distinctive characteristics of the models from the same series is the illumination, which here is orange.
Pioneer DEH-S101UB
Pioneer DEH-S101UB — This is an entry-level CD receiver with built-in 4x50 watt power amplifier and a high / low pass filter - everything to get you into an atmosphere of loud and high-quality sound. Supports smartphones with Android OS. And you can not only listen to music, but also charge the battery in parallel.
The screen displays Cyrillic characters. The buttons and the display are illuminated. Brightness control for 10 gradations and a special timer for lighting. Ideal for listening to music on the go.
Pioneer DEH-S101UBG
Pioneer DEH-S101UBG — budget version of the CD receiver with the ability to play music using USB and AUX-inputs. The green backlight allows you to comfortably operate the device even when the light is on. You can connect the remote control. Equipped with a built-in MOSFET amplifier, but if its capabilities are not enough, you can use a special input to connect an external amplifier.
The application allows you to manage the media receiver from your smartphone's screen: now you do not need to additionally record music on external media.
Pioneer DEH-S2000UI
Car Receiver Pioneer DEH-S2000UI provides all the possibilities for obtaining high quality sound. So, it is equipped with a built-in amplifier with a power of 50 watts per channel. If this is not enough for you, you can connect an external amplifier or a subwoofer using the preamp output.
You can play music using USB storage devices, as well as from smartphones or tablets based on Android or iOS. If you are going to a long journey, the Mirtrax function will create for you a unique mix with all audio: you will feel the sensations of this party driving your own car. Quick Charge for Android - charge devices with Android OS.
Pioneer DEH-S3000BT
Head Unit Pioneer DEH-S3000BT allows you to hear old compositions in a new way. The main distinguishing feature - built-in microphone: phone calls on the speakerphone and karaoke right in the salon of your car.
You can connect two devices using Bluetooth. Equipped with a built-in power amplifier, but it is possible to connect one more for the rear speakers or subwoofer.
Pioneer DEH-S4000BT
Model Pioneer DEH-S4000BT equipped with everything necessary for high-quality music playback: CD-drive, Bluetooth, RDS-tuner, USB, AUX-input and the ability to connect iPhone and Android. Equipped with a built-in microphone for talking in hands-free mode.
You can connect up to two devices with Bluetooth: from one listen to music, from another - communicate.
Pioneer DEH-S5000BT
Car Receiver Pioneer DEH-S5000BT Compatible with iPod, iPhone and Android. For the latter, the battery can be charged. A distinctive feature of the model is the function of karaoke: connect the microphone and you can sing and hear yourself in the speakers.
The device can be controlled using a special application. There is an opportunity to talk on the phone using the technology of hands-free: the sound quality is much higher than when talking on the speakerphone.
Pioneer MVH-S100UI
Model Pioneer MVH-S100UI It has a shorter body - 41% less than usual: it simplifies the installation process. It is possible to connect an additional amplifier or subwoofer. Equipped with steering control panel Energy-saving mode, red button illumination is provided. Supports iPhone and Android. Can charge the battery.
Pioneer MVH-S100UB
No restrictions in listening to music: connect to the receiver Pioneer MVH-S100UB external devices, Android smartphones, in parallel charging the phone's battery. There is a built-in amplifier with a power of 50 watts per 4 channels, but if this is not enough - connect an additional amplifier.
There is a backlight for buttons and a display with a dimmer and timer. Advanced Sound Retriever provides improved quality of compressed files.
Pioneer MVH-S100UBG
USB and AUX-inputs, support for Android, power amplifier for 50 W, support for FLAC format - everything so that you can enjoy high-quality sound of music in the car.
One of the features Pioneer MVH-S100UBG — the ability not only to listen to music from the smartphone, but also to charge it. Now the cow became shorter - 41% less than usual. For self-adjustment of audio at your disposal 5-band graphic equalizer.
Pioneer MVH-S100UBA
Maximum output power Pioneer MVH-S100UBA is 50 watts for each of the 4 channels, and if this parameter is not enough for you, you can connect an additional amplifier: there are special inputs. Equipped with a low-pass and high-pass filter with a 5-band graphic equalizer. So, you get all the options for setting a quality sound.
Supports Android: music playback and battery charging.
Pioneer MVH-S100UBW
Customize to one of 24 preset FM radio stations or connect your audio using USB, AUX-inputs and Android. Front panel of the receiver Pioneer MVH-S100UBW removable. There is a white button illumination. Equipped with a protective case for the front panel. There is an automatic search for the desired frequency.
High and low frequency filter, graphic equalizer - all in order for you to get the best quality sound.
Pioneer MVH-S300BT
Expand your capabilities with the receiver Pioneer MVH-S300BT — connect two smartphones with Bluetooth: one for listening to music, the second - for calls with the function of hands-free. For iPhone there is a way of voice control with the help of Siri.
So, with this device you completely immerse yourself in the music world at the wheel of your car.
Pioneer AVH-Z5000BT
Radio tape recorder Pioneer AVH-Z5000BT has advanced capabilities for connecting devices: Android, Apple, USB-input, CD-ROM. Use Apple CarPlay, Android Auto, and Waze. Wireless connection and control of the radio via Bluetooth are provided.
The sound process is the control of the 13-band equalizer, the time delays, the improved crossover: everything to make you enjoy the sound quality. Buy car receiver Pioneer in Kiev, Kharkov, Odessa can be at 130.com.ua with delivery across Ukraine.
See video reviews of car radios
Related materials
Car stereos: Best Sellers
