Radar Detector and Seasons
The radar detector is a fine-tech electronic device that is used in a vehicle to detect radars and humidity and temperature fluctuations characteristic of the use of the device in certain conditions. The characteristics of a radar detector in most cases indicate a rather large temperature range: from minus 30 to plus 70. Will this interval be sufficient and how can the radar detector be protected from possible consequences, in terms of failure when the temperature rises or falls interval? And what else do you need to know and what should you fear for durable operation of a radar detector?
The climatic conditions of Ukraine are very picky, and after the burning winter frosts almost tropical heat comes with heavy rains. It seems to be the maximum temperature and does not exceed the permissible level of 40-45 degrees. But it is worth bearing in mind the installation site of the radar detector: perhaps under glass, and maybe on the dashboard, which in hot weather under the rays of the sun heats up to such an extent that it is impossible to touch it. Here all hopes are placed on the reliability and quality of the radar detector itself!
The owner of a high-quality radar detector can completely trust the manufacturer, because it is he who must reliably design the device before the manufacturing stage. The “hottest” component of a radar detector is its power supply stabilizer, which needs thermal protection in the form of a radiator, which is combined with the body of the microwave signal processing unit. It is from this moment that the “pitfalls” begin.
For example, the Whistler PRO series radar detectors from the PRO series are not often cheap and there are cases of excessive radiator overheating in very hot weather, especially when using a radar detector on a car dashboard. The result of overheating is obvious: a natural change in the parameters of radio components, which leads to the device's inoperability-malfunctions begin to work, the sensitivity of detection of radar decreases significantly, the number of false alarms increases. you can buy a radar detector in Odessa, Kharkov and Kiev on 130.com.ua with delivery in Ukraine. << p>
What is the conclusion of all of the above? Reliably clean up the radar detector from direct sunlight in most cases will not work: you probably know that there are some requirements and instructions for installing a radar detector in a car. Only one way out-you need to be as careful as possible when choosing a radar detector, having decided on reliable models that are specially adapted to our difficult climatic conditions!
See video reviews of radar detectors
Materials on the topic
