Proper configuration of rear-view mirrors and features of the use of mirrors "dead zone"
Drivers must use rear-view mirrors to ensure safety while driving. With their use, you can control everything that happens outside the car and, of course, avoid accidents or accidents. However, in order for the use of mirrors to be as efficient as possible, they need to be not not only installed correctly, but and be adjusted to obtain the maximum viewing angle.
Many drivers disregard the this procedure, as a result, the occurrence of an emergency will be inevitable. It may occur during rebuilding or overtaking another car, because often vehicles that move in the opposite direction may be lost from sight. Therefore, the correct adjustment and setting in the the correct position of the mirrors, will help control the situation and prevent the occurrence of an unexpected incident.
How can you avoid a “dead zone”?
The “dead zone” is a certain part of the space located in the rear part of the vehicle that is not viewed by the driver during driving time. In other words, the space that does not cover the rear cabin and the side mirrors is a “blind zone.”
The reasons for the appearance of such zones are:
- wrong setting of rear-view mirrors;
- having high head restraints in the seats;
- transportation of large loads;
- high rack body;
- transportation of large passengers.
Avoid the emergence of "dead zones" will help the correct setting of mirrors or constant turns of the head to be able to see everything happening behind the car. However, the dead zone mirror is considered the best option to get a complete overview in the rear of the vehicle. Installing it will help you get a larger viewing angle, and these “blind spaces” will simply disappear.
Features and Dead Zone Mirrors
Similar elements for review provide accurate and clear information about those parts of the road that may be hidden from the driver’s gaze on the road surface. The presence of a “blind zone” is one of the important and complex phenomena on the road that must be carefully avoided. Especially important is the acquisition and the installation of dead-zone mirrors in new car drivers for new drivers, to avoid emergency situations and to ensure safety during driving time.
Among the mirrors, the “dead zone” is the most popular and utility model is an aspherical device. These devices are divided into 2 zones:
1. the main part of the product is larger, it is located on the near side of the driver. It is a conventional spherical mirror, whose viewing angle does not exceed the usual size of the mirror;
2. the secondary part of a reduced size, which is the main element that expands the viewing angle. This is done by reducing the level of curvature at the far end of this element. This allows the driver to see everything that is in the “dead zone”.
When buying, it is important to choose the necessary option among the presented types of mirrors "dead zone" for your car. It can be a device in the form of a miniature optical element that can be fixed on the side mirror or a single element that is mounted above the main mirror. A huge selection of such accessories can be found on our site, here you can find a wide range of accessories suitable for each brand and car models. you can buy rear view mirrors on 130.com.ua with delivery to Kharkiv, Odessa, Kiev and Ukraine.
It is important that after the purchase and installation of the dead-zone mirror, it is good to adjust this fixture. To do this, the driver needs to sit in a comfortable position behind the steering wheel and look in a mirror. If in it is not some areas are traced in which contain moving objects, then it must be adjusted well so that such “dead zones” do not arise.
Tips to ensure a safe ride
Each driver, in order to avoid accidents on the road, must adhere to certain recommendations, in particular, in a timely manner, look at the rear-view mirrors.
- You need to look in the mirror before doing the maneuver — starting from the parking lot, overtaking, or rebuilding on the road.
- Braking must be accompanied by a view of the road in the rear-view mirror, which is located in the car salon.
- Driving using the reverse gear should also be accompanied by alternately viewing the area behind the car in the salon and the side mirrors. In the case of equipping the car with a rotating electric drive, then you can change the position of the side mirror so as to increase the view near the vehicle.
- Before leaving the car, the driver or passengers should also look at the side mirrors. Therefore, only after the permission of the driver, the passenger can leave the car.
It is also extremely important to adhere to recommendations regarding the rules of behavior on the road, making driving safer. This primarily applies to turn signals, as timely turning on or off turning signals are guaranteed to prevent accidents. Also, you need to adhere to a smooth driving style, observing the necessary speed limits on the road.
Thus, with properly adjusted mirrors and by following all the unspoken rules of the road, you can protect yourself and passengers from an emergency. A equipment with all necessary accessories will allow you to have a circular view of your car, avoiding the appearance of "dead zones".
Materials on the topic
Parktronics: Best Sellers
