Built-in seat heating for popular brands-Emelya, Mitsumi and GT
To ensure a more comfortable and, most importantly, a warm stay in the car in the winter, you will need to install additional equipment, and it is heated seats. With it, in the cold season you can protect yourself and your body from hypothermia.
In some vehicles, there are already installed devices for heating the regular type, however, many auto models all are produced without this modification. Therefore, the purchase and installation of this device will be more than necessary.
Functional features of built-in seat heaters
There are two types of heating that are installed in car-recessed and capes-covers. We will consider the first option, find out its features and the advantages of the functional.
Recessed seat heating is a much better option than capes. First of all, this is displayed in their functionality because they are more powerful and have more options and features. In addition, they differ:
- aesthetic, they cannot be seen because the installation is done under the skin;
- power on and power off using the button on the panel;
- you can customize the power modes by selecting the necessary parameters;
- connection is via the onboard network;
- longer life compared with ordinary capes.
However, despite the number of advantages, there are some features of these heatings:
- impossibility of self-assembly;
- cost more than buying capes.
On the other hand, many car enthusiasts are paying more attention to the functionality and additional features, which makes recessed seat heating more popular.
Features of heating design
A built-in heating element is installed between the cladding material and the seat cushion. Manufacturers make them in the form of special mats, made them reinforced wires or webs of carbon fiber. Their main features:
1. devices that are made of nichrome spiral in PVC sheath have a construction of threads across or continue. Differ in certain difficulties in installation, because their need to adjust to the shape and the design of chairs in the avoid intersections with reinforcing elements. Sometimes these complications are solved using double-sided tape;
2. mats that are made of carbon fiber or fiberglass materials are easier to installation. On them, you can make cuts in the right areas for fixing fitting components and location on the surface. They are also more reliable.
Among the possible options for control of heating there are traditional and electronic control models. In the first case, the device is operated only in "on" or "off" mode. In the second case there are more interesting features for the functional-there are several heating modes, and there is also an option to automatically turn off after 30 minutes of continuous operation.
Market Leaders-Emelya, Mitsumi and GT
Among the most popular and popular models of built-in heating are distinguished products of these brands-Emelya, Mitsumi and GT. Consider the features of their products in more detail.
Excellent quality at an affordable cost-Emelya’s built-in heating elements
The Russian manufacturer of heating, producing products under the brand Emelya, is considered the leader in the budget options market These devices are characterized by high quality of performance and a relatively low cost. The main features of these devices:
- high heat level;
- Execution using reinforced wires located in snake-like form;
- The design of heating elements includes carbon fiber, which contributes to more reliable use and, in the event of one or two fibers failing, the others will also work, giving off less heat;
- The presence in some models of the color indication of seat heating, which determines the intense, strong, medium and weak level of heating;
- choose a model with 2, 3 or 5 levels of heating;
- auto power off after 30 minutes of continuous operation;
- there are models for trucks and passenger cars, universal and for a specific vehicle model;
- protection against short circuits and overheating, and also against sparking.
The main feature of this equipment is the production of heating elements using a special, actually developed technology, thanks to which Emelya seat heating is reliable and durable products with a long service life. The most famous and popular models are considered the CC and UK2.
Quality and Reliability of performance-Mitsumi embedded reheat
The original and reliable Taiwanese-made heating models are tailored to the preferences and for the comfort of many drivers. Among the presented options of heating elements distinguish products with two, three and five levels of heating. Main features:
- availability of multiple heating modes, and also a knob for setting the required heating intensity;
- you can use the auto off function after 30 minutes of continuous heating;
- double protection against short circuit and overheating;
- in some models, the presence of an electric massager function for a more comfortable stay in the chair during the travel time;
- making heating elements or carbon fiber mats;
There are universal options and those that fit exclusively in certain models or brands of cars. There are products for use in Toyota, Mazda, Hyundai, Nissan, and also in Lexus RX300/350, Toyota Land Cruiser 200 and Toyota Prado 150.
Comfort and quality heating with GT brand products
Heaters for GT seats are easy to install and high quality performance. Each model is made using carbon fiber, suitable for installation on any seat, with any fabric covering. Features of the devices of this brand:
- warm up to 40 degrees and then turn on the mode of maintaining the level of heat;
- safer because they are protected from mechanical damage;
- additional protection against dust and moisture;
- automatic shutdown when heating reaches 65 degrees & nbsp;
- overheating protection and short circuit;
- models with 2,3, 4 and 5 levels of seat heating are presented.
In addition, there are also universal devices and those that are suitable for a particular brand or model of car-Toyota, Volkswagen or for the Toyota Land Cruiser.
What do we take into account when choosing
Provide some important tips recommended when choosing built-in seat heating.
1. The manufacture of high-quality and durable materials that provide the necessary degree of fire safety.
2. The presence of temperature sensors and several heating modes-not a very important, but predominant factor.
3. Auto power off and support a certain temperature for a while.
4. Having multiple levels of protection is extremely important because it contributes to the safety of the driver during the trip. These include protection against short circuits, overheating or overload, and also sparking.
5. Uniform heated seat, and not only in one point.
In addition, they should be easy to install and minimally visible on the seat, because ergonomics and an excellent combination with the overall design of the cabin are important factors due to which most people choose to buy and install heated seat recessed./p>
Materials on the topic
Seat warmers: Best Sellers
