Useful features car vacuum cleaner, what to look for when choosing a
Car vacuum cleaner can be a very useful acquisition, of course, if it is high-quality and functional. Good device from trusted brands of well cope with the removal of dirt, dust and small debris from the car seats. With this gadget cleaning machine is easy and fast.
Let's look at what options Cleaners should pay attention when choosing. And what useful functions can have these devices.
Basic functions, which should have the right car vacuum cleaner
To Cleaners were easy to use and it is a long time served before buying look at the quality of the instrument, including the fact of what made his case. The quality of the assembly depends on its longevity. Many have been able to verify that the anonymous Chinese gadgets that can be found in large numbers on our car markets, often quickly break down, and their effectiveness is questionable, pull they are usually very bad. Therefore, it is better to look at the technology of proven brands: Daewoo, HEYNER, Dometic, Belavto and other
.Of course, choosing a car vacuum cleaner look on his power. Here everything is clear, the more powerful the machine, the better it works better collects fine debris and dust. To clean the interior suitable device with power from 30-40Vt such cope with minor impurities and dust. If you want your vacuum cleaner can remove larger contaminants such as wool and leather, adhering dirt and others, it is worth paying attention to models with output power of 100 watts. Such vacuum cleaners can remove almost any dirt.
The important parameters which you should always look before purchasing Cleaners:
- Power control. Such models allow the use of a vacuum cleaner in several modes, it is more convenient. At various impurities can be controlled suction power, which greatly simplifies the work. Such an option is most relevant for wireless devices that operate on the battery, as when removing small impurities, which do not require more power, you can conserve battery power.
- The amount of the dust collector. Capacity of dust collecting container should be sufficient to carry out a complete cleaning of the entire vehicle. Cleaners Most models have a 1.5-liter dust bag, and this will be enough to clean the machine when soiled. If we get out of you often, or garbage in the car builds up a lot, for example, have to carry small children, who throw food and a lot of crumble, or pets that are always left his coat, it is better to choose a model with a larger one container for collection of debris and dust.
- Interchangeable nozzles. Their presence enhances the vacuum cleaner. For example, some models are equipped with a turbo brush, which is well eliminates the wool, or a special nozzle for narrow high-quality cleaning in crevices and hard to reach places. The more complete with additional accessories Cleaners is, the easier it will work with your device.
- The inner filter cartridge. There may be two options: a disposable or reusable. The first will have to buy extra, because after each cleaning the filter should be changed. A second more practical because they can be used long enough only carefully washed after each use of the vacuum cleaner. Note, sometimes special detergents may need to clean the filter.
- Battery capacity. This is true for wireless models, here it is important to make sure before buying that the battery will last for a full cleaning. If unsure, it is best to look at the options that are operated via the cigarette lighter. They even pulled by a wire, and someone this may seem inconvenient, but it does not shut off at the most inopportune moment, when cleaning is almost finished.
- Power Cord length. It is important for wired models that are powered by the cigarette lighter or other power source. This point is often overlooked, but it is very important, how to work with the vacuum cleaner should be comfortable. If the wire is short, it will not make it to all corners of the cabin, where just most often accumulate a lot of dust. The wire must be long, it is best that it is not enough just to clean inside the car, but could even reach the trunk.
- Dimensions and weight. Cleaners should be easy to handle. Most of the models are not heavier than 1.5 kg, this average. There are, of course, very tiny variations that can easily fit into the trunk even when working with them hand does not get tired. They tend to choose women to always have on hand a compact tool for cleaning. But the power in these vacuum cleaners are usually small, they can not cope with a serious pollution. If the models and more powerful, they may be the overall and heavier, but cleaning in this case will turn out better. And then everyone decides for himself what is more important: the lightness and compactness and high performance .
Additional useful features Cleaners
When buying a vacuum cleaner in the car, it is equally important to clarify also what this model has additional features. Now, many manufacturers equip their devices some very useful features. For example, it is not superfluous will be the following:
- Wet cleaning. A vacuum cleaner with a similar function are not afraid of water, it can not only possible to carry out wet cleaning of seats, but also to collect spilled liquid. In addition, such models do an excellent job with snow removal, which was brought from the street and managed to melt. It is very convenient and useful option for all drivers, especially for parents with young children, who are often shed in the back seats sugary drinks, and there is not quickly eliminate the mess, then left an unpleasant sticky spot.
- The steaming function-like function in the car vacuum cleaner is extremely rare, but if it is, it is very important in our environment. Let such a vacuum cleaner and do not replace a full-fledged professional dry cleaner or washing vacuum cleaner, but it will allow for a sanitary salon treatment.
- Backlight-also a very useful option. The interior lighting, especially in corners and hard to reach places, usually small, and if your vacuum cleaner has a built-in flashlight, cleaning is much easier. You will be able to see all the debris and remove it as thoroughly as possible, without losing anything. You do not have to ask somebody to shine, or try to hold in one hand, flashlight in the other vacuum cleaner to get to the garbage. All will be well seen without it.
If you want to buy car vacuum cleaner in Kiev, Kharkov and Odessa, the online store 130.com.ua you will find a large selection of models at an affordable price .
Related materials
Car vacuum cleaners: Best Sellers
