New solutions for tape receiver functionality 2019 – Pioneer SPH-10BT
In the series of Pioneer receivers was released new model SPH-10BT, equipped with an anchor for the smartphone. Its functionality combines all the innovative technologies that used in modern tape receivers. This highlights the device among others and makes it an indispensable attribute of your car.
External features
The strict and laconic design of the tape receiver can be fitted with a smartphone of any color, it would be appropriate to look and decorate the car panel. The fastener perfectly fixes the phone horizontally or vertically, at the driver's choice. There is also an adjustment feature, so you can always see what you need on the screen.
Radio tape recorder + smartphone
To the Pioneer SPH-10BT you can connect a smartphone, and with the tape receiver to manage all its functions. The connection is possible via Bluetooth or through USB port.
At the beginning of the work, you need to download and install the application – Smart Sync. With this combination you can quickly access all the features of your smartphone. And that:
- voice control;
- calls and phone book;
- You can listen to SMS using the voice menu;
- fast access to navigation applications;
- convenient intuitive menu.
You can also connect the optional ND-PS1 parktronics to the cassette player, with which the parking process will be faster and more secure.
Auxiliary features – connecting the parking radar ND-PS1
Functional radio receiver impresses not only with its direct, but also auxiliary functional features. These include the option of connecting an optional parktronic ND-PS1, which will make the parking process more secure and time-consuming.
Features of ND-PS1 parking radar model:
- possibility to display information on a smartphone;
- indication by sound or backlight on the main unit;
- availability of 4 parking sensors;
- connection via UART connector;
- the minimum and maximum detection distance is 0.3 and 2.5 m, respectively;
- generating an ultrasonic pulse at a frequency of 40 kHz.
The ND-PS1's Parkrunner will perfectly complement the Pioneer SPH-10BT and will be a good helper for easy and safe parking.
New sound opportunities
In this model, the receiver’s manufacturer combines sound settings with the advanced functionality. During the device, you can quickly adjust the sound to the required type of car. There is also a 31-band equalizer for adjusting the sound quality of music in the car.
Other features for audio tracks are:
- temporary delays;
- the presence of a crossover;
- spatial sound settings.
The use of the Pioneer SPH-10BT receiver will add new colors, velvet and contrast to the sound of your favorite music.
Illumination features and theme setting
For those who want to experiment with colors, this is the perfect way to set the lighting settings according to style or mood. The receiver function has a multi-color display panel and buttons, you can choose any shade that will fit the design of the interior or your smartphone.
Separately, I would like to highlight the installation of themes on the tape recorder. Here you can use animated themes that will be different by their unusual and original look. Also, during the incoming call will be activated the light notification.
What’s the difference of the Pioneer SPH-10BT receiver model?
So, let's draw conclusions. The innovative Pioneer SPH-10BT receiver is a unique model of a well-known company which is suitable for enthusiasts of truly high-quality music. Its advantages:
- is equipped with a fix for the smartphone;
- the ability to control the smartphone from the tape recorder and vice versa;
- you can connect parktronic (model of Pioneer ND-PS1);
- equipped with 31-band equalizer;
- 2 RCA connectors;
- supports Android OS;
- suitable for iPhone use;
- equipped with Bluetooth wireless communication;
- RGB backlighting model;
- ability to compress audio data without loss of sound quality using the FLAC codec.
Thus, having chosen the Pioneer SPH-10BT receiver, you will get a beautiful and easy to use receiver with high quality sound of your favorite tracks.
Buy receiver Pioneer in Kiev, Kharkov, Odessa with delivery across Ukraine it is possible on 130.com.ua.
Materials on the topic:
Car stereos: Best Sellers
