Pioneer cassette players with CD drive 2019 – the best music in your playlist
Every driver wants a quality and clean sound of music in the car. This is possible thanks to the cassette player with a drive from the company Pioneer. You will get beautiful and transparent sound from the licensed disc of your favorite tracks and you will enjoy music throughout the trip. Let's consider some of the features of the models presented by Pioneer.
What's New in Pioneer DEH-S110UB?
With a Pioneer DEH-S110UB receiver, the sound of music will be cleaner and more powerful. It is possible to listen to music from CDs, it is possible to connect a smartphone based on Android.
The receiver embedded in a powerful MOSFET amplifier, which has four channels of 50V. If this system is not enough, you can connect the amplifiers, for this is equipped with a RCA connector. Consequently, the main features of the tape recorder include:
- availability of USB port;
- 5-band equalizer;
- Android support;
- there is one RCA connector;
- support FLAC technology for converting audio tracks without losing sound quality.
Also, in the cassette player is installed Pioneer ARC application for more features with your smartphone. It is a remote control system, which turns the connected device into a powerful tool for managing all functions of the car radio.
A simple classic in your car – Pioneer DEH-S110UBB
New features open using the Pioneer DEH-S110UBB receiver. Good functional, excellent characteristics make it an indispensable element in the car's interior. The presence of the MOSFET amplifier makes the sound more powerful and contrasting, bass sounds great, only high-quality sound transmitted through the dynamics. Main characteristics of the model:
- connecting an Android smartphone;
- iPhone support;
- 5-band equalizer;
- built-in USB port;
- equipped with 1 RCA type connector;
- availability of the Pioneer ARC application.
Thanks to working with FLAC codec technology, you can convert tracks to MP3 or WMA format with preservation of quality and purity.
Functional extension in the Pioneer DEH-S110UBG
All the main functions of the previous models integrated into the Pioneer DEH-S110UBG receiver. The beautiful and laconic design, easy to use display makes this recorder the best in its series. Its main characteristics:
- you can connect a smartphone with Android OS;
- iPhone work;
- equipped with USB port;
- there is 1 RCA connector;
- 5-band equalizer;
- includes Pioneer ARC application.
This receiver also has the function of FLAC codecs for the conversion of melodies. With its help, you can play regular music while maintaining the sound quality on the licensed discs.
Clean and sound quality with Pioneer DEH-S110UBA
Frequent and long trips are sometimes very debilitating, so listening to music can be the only entertainment. In addition, here the main sound quality and reproduction power. With it, the Pioneer DEH-S110UBA receiver can easily handle it. Its powerful bass and clear sound gives you the pleasure of listening, and the trip will be surprisingly quick and enjoyable. The functional represented by the following features:
- possible to work via USB port;
- connecting a smartphone with Android;
- 5-band equalizer;
- possible integration with the iPhone;
- there is 1 RCA type connector;
- FLAC function with frequency 48 kHz/16 bit;
- support Pioneer ARC application.
Thanks to these features, the Pioneer receivers are the best in the line of tape recorders that reproduce the sound at the highest level.
New in the world of pure sound – Pioneer DEH-S111UB
The classics in the world of recorders – the Pioneer DEH-S111UB, makes listening to your favorite tracks high quality and clean. The built-in MOSFET amplifier adds power and transparency to the sound. If this is not enough, it suggested buying a subwoofer or a separate amplifier for more power.
This device has the following features:
- work via USB port;
- works with Android;
- availability of 5-band equalizer;
- integrates with iPhone;
- available in 1 RCA connector;
- equipped with the FLAC function of the codec at 48 kHz/16 bit.
Thanks to Pioneer ARC, the smartphone or iPhone converted into a device for remote control of all functions of the cassette player. It is very practical and convenient for many drivers.
New functionality for the Pioneer DEH-S111UBG
The laconic external display with the «removable panel» function prevents the theft of the Pioneer DEH-S111UBG receiver. This is a completely new, improved model from the line of data devices. Specific model functions:
- equipped with a USB port;
- work with smartphones based on Android and iPhone;
- equalizer of 5-way type;
- there is 1 RCA connector.
Thanks to the FLAC codec's function, music converted without loss of quality or purity. Works on an ultrasonic frequency of 48 kHz/16 bits.
Enhanced receiver capabilities – Pioneer DEH-S210UI
New cassette player Pioneer DEH-S210UI has a wonderful functional. With its help, you can listen to music in the «non-stop» mode, because here is the function MIXTRAX. Its feature is the selection of music of similar tonality, tact and motive, after which one long track mixed with it. Thus, you can choose your favorite playlist without spending time on its formation. Other receiver capabilities:
- the presence of a USB port for connecting other devices;
- there are 2 RCA connectors;
- integration with Android OS and iPhone;
- 5-way equalizer;
- supports Pioneer ARC application.
In addition, in the Pioneer DEH-S210UI you can customize the color shades individually – separately for the central and the outer edge of the front panel. The color scheme consists of more than 200 000 shades.
We sing in karaoke with the Pioneer DEH-S310BT receiver
The new series of recorders Pioneer DEH-S310BT impresses with a wide functionality. Especially the karaoke function highlighted, which makes the device more popular. In addition, it proposed to install the microphone as a loudspeaker during the tour, which makes the device indispensable in such cases.
Features of the Pioneer DEH-S310BT Receiver:
- there is a USB port for connecting devices;
- work with Android smartphone;
- 13-band equalizer;
- equipped with FLAC codec at 96 kHz/24 bit;
- it is possible to work on Bluetooth, simultaneously with two devices.
With the tape recorder, the Spotify or Pioneer Smart Sync software used to get better and fast music from your smartphone.
Classics and Style – Pioneer DEH-S410BT
The device Pioneer DEH-S410BT combines all features of the previous model and is additionally equipped to connect to the iPhone. In functionality of model 310, this feature is absent. Thus, the basic functions of the Pioneer DEH-S410BT are:
- it is possible to connect other devices with a USB cable;
- it is possible to work on Bluetooth, with two devices simultaneously;
- use the Spotify or Pioneer Smart Sync application.
In addition, the Pioneer DEH-S410BT features a removable panel with anti-thief function.
Generation of new tape recorders – Pioneer DEH-S510BT
The stylishness and laconic design, a large functionality are well combined in the unique receiver Pioneer DEH-S510BT. Its functionality is simply impressive:
- karaoke function;
- connect via USB;
- there are 3 RCA connectors;
- integration with Android and iPhone;
- work on Bluetooth with two devices simultaneously;
- work with Pioneer Smart Sync;
- there is a separate RGB backlighting;
- built-in DSP sound processor.
In addition, the Dynamic Bass Enhancer feature makes the sound more intense and energetic, without overloading the volume of the dynamic. The result is a deep and bass sound, even if relatively small dynamics installed.
How to choose?
The answer is very simple – rely on your wishes. If you need professional and more powerful sound, then we offer DEH-S210UI, DEH-S310BT, DEH-S410BT or DEH-S510BT. Otherwise, for those who prefer a classical receiver with no less broad functionality, then you should choose between DEH-S110UB, DEH-S110UBB, DEH-S110UBG, DEH-S110UBA, DEH-S111UB or DEH-S111UBG. Choose only high quality and powerful sound from Pioneer's head unit.
Buy receiver Pioneer in Kiev, Kharkov, Odessa with delivery across Ukraine it is possible on 130.com.ua.
Related materials:
Car stereos: Best Sellers
