Modern anti-theft security systems: features and varieties
Now, no car can be left without additional protection against theft, since the statistics of vehicle thefts are very disappointing. Every car owner knows that car alarms are one of the must-haves, especially if the car is new and expensive. Naturally, many seek to maximize the level of protection: install additional mechanical and digital locks, trackers, etc. Therefore, many manufacturers of security systems began to offer ready-made combined systems. Such security complexes are distinguished by wide functionality and great capabilities. We will talk about them in this article.
What are the features of modern security anti-theft systems
Features of security complexes
Each car owner has the right to independently choose which security system to use to protect his vehicle. There are various threats; cars will be stolen from parking lots at the supermarket, and from paid parking lots, and even from garages. Therefore, first you need to decide which tasks the security complex should solve in order to provide maximum protection for your particular car, taking into account the features of its operation. The system bundle will depend on these tasks.
All security systems can be divided into several types according to the type of tasks being solved:
Alerts
Systems of this type usually consist of car alarms. When the machine is armed, all the main alarm modules and additional GPS systems are activated.
Such security systems are designed to monitor the condition of the vehicle, control its location and route. They have sensors and a data transmission system, the first detect attempts to hack or mechanical impact on the car, and the second transmit an alarm to the owner, notifying of theft or other unforeseen situations.
The task of such security systems is only to activate sound and light alarms. Additionally, the complex can perform auto-start of the engine, block the motor and car doors and monitor the movement of the car, passing the current coordinates to the owner.
Active Security Systems
Kits of this type have the widest functionality, they consist of a car alarm, an immobilizer, an additional hood lock, devices for locking the gearbox and steering, as well as trackers and additional devices for GPS monitoring of the vehicle’s position.
A similar set of devices provides maximum protection in different areas. In particular, the alarm detects and reports hacking attempts, the immobilizer allows you to block the engine, the hood lock prevents the criminal from entering the engine compartment, where the engine is located and most often the alarm control unit is located.
Recently, the use of special electronic secrets has become characteristic of active security systems. Complementing the alarm system, they can become a serious obstacle that will be difficult to overcome.
The use of devices blocking the vehicle’s diagnostic connectors allows you to close access to vehicle control systems and installed alarms as much as possible. Many modern cars have a similar option. However, such protection will be powerless when hijacking with a tow truck.
Passive safety devices
Passive-type security systems suggest the presence of special electronic beacons and satellite bookmarks. They do not interfere with the hijacking, therefore they are called passive, however, they allow obtaining data on geo in real-time graphical position of the vehicle. The owner can enter a special application on a smartphone or an online service on a computer and see the coordinates of his car on a map.
Of course, everyone decides which type of security complex suits him best. The choice of systems in stores is very large, they can have different functions and equipment. You can either buy ready-made systems for protecting the car, or build the system yourself by adding additional protection modules to the alarm system.
The difference between security systems and car alarms
Comparing security systems and car alarms, it is impossible to say unequivocally that it is better to cope with the protection of the car. It all depends on the challenges facing the car owner.
Of course, it is easier to set the alarm and it takes less time, while most modern alarms have many additional service options, and can solve a wide range of tasks. Basically, this is an alert about unauthorized access to the car. Using the service options allows you to make the operation of the alarm convenient and comfortable.
In contrast to the alarm system, the security complex provides for the use of several protective components at the same time, which are combined into a common system. Modern car alarms allow you to connect other electronic protection systems:
  • GPS module;
  • immobilizers;
  • different sensors: movement, tilt, shock and others.
Complexes also include mechanical means of car protection, various locking systems, electronic components of blocking, through the use of which the level of reliability of the car protection system is increased.
What functionality do security complexes have
All security systems offered by manufacturers for vehicle protection have a different level of protection. There are three main groups:
  • The Economy option is the simplest and relatively inexpensive basic equipment, which consists of a car alarm, a mechanical lock and an immobilizer.
  • Compact-this group includes complexes that, in addition to signaling, include advanced digital engine blocking systems, as well as advanced locks and security systems that limit unauthorized access to the engine compartment.
  • Premium class-it includes the most advanced and expensive security systems, which consist of the most advanced multi-functional alarms, supplemented by GPS/GSM modules that allow you to control the movement of the car and quickly detect it in case it’s appropriate.
Naturally, the more components there are in the system, the higher the level of protection. Therefore, at present, more and more car owners are choosing security complexes that can ensure the implementation of a full range of measures to prevent theft. Complex solutions are considered more reliable, since they insure several risk zones at once, minimizing the likelihood that criminals will be able to take possession of the car.
In the online store 130.com.ua you can buy an alarm system or a security complex for a car of any class and brands. We work with leading manufacturers of automotive security systems.
TOP-3 car alarms
Best alarms on the car
Looking for a quality and the best car alarms? This rating of car alarms is made on the basis of such parameters as: high demand with positive feedback from our customers, high-quality manufacturing — absence of factory defects and service calls, and official warranty and post warranty support in Ukraine.
Car alarm Pandora DXL 4710
Features:
  • ★ with engine start
  • ★ with 3xCAN, 2xLIN, GSM, GPS and Bluetooth
  • ★ High security against burglary
Car Alarm daVINCI PHI-330 PRO
Features:
  • ★ With feedback
  • ★ Interactive code
  • ★ Two-level shock sensor and G-sensor
Car alarm Sheriff ZX-1090
Features:
  • ★ Dynamic Code CFMII
  • ★ Anti-Frame mode ("Anti-Hi-Jack")
  • ★ Radius of action up to 2000 m
Related Content
Car alarms: Best Sellers
