Features and benefits Simarine monitors for boats and yachts
The revolutionary smart displays battery status with the monitor-a novelty on the Polish brand Simarine. This is the perfect system battery monitoring, which sets new standards for control and analysis. This indicator provides an accurate measurement of voltage, current and temperature of your battery, gives the correct status of the battery status, detects wear of batteries and a lot of other useful information.
Why do you need a monitor batteries on the boat?
This is a special monitor device which can control the state of the electrical system of a swimming means. Through the installation of special sensors current indicator measured at the output of the generator, as well as inlet and outlet installed service battery. Also monitors performance and starting batteries, but they are usually controlled by a voltage level.
Monitor battery status-this is not a trivial counter ampere-hours, and a modern intelligent device that can simultaneously monitor multiple parameters. Before working in the unit, enter the nominal capacity within a few cycles of the battery unit will "learn" and then will have to work completely autonomously without additional external intervention. The monitor will check the level of current, voltage and temperature of the battery, then will compare these data with a predetermined battery model. All indicators on each power supply, and the current settings are displayed on the screen, and at any moment you can check the real-time condition.
These monitors are capable of controlling how one or several batteries. The most simple basic devices typically measure only the voltage, current and charge level of the battery. More complex and functional models can monitor the status of two, three and even four batteries. It is usually from the main power source is monitored component of voltage, current and state of charge, while the other-the voltage and current or one voltage
Models having the modular construction principle (refer to this type Simarine monitors) allow to add chain multiple independent current sensors or intelligent shunts. Such devices are capable of controlling up to 6 batteries.
A properly installed battery monitor-an indispensable tool that will allow us to identify a fault in the electrical system of the boat or boats. For example, the device easily detects when the solar panels are polluted and can not cope with charging batteries. You will always know exactly what it is time to charge the battery.
Features and Benefits Monitor Simarine
Monitors and battery status indicators Simarine have good functionality and reliability. Thanks to its modular design, you can upgrade and expand its capabilities as needed system. In this case, the main advantages of the system are:
- Mobility . You can gain remote access to the device and its data anytime, anywhere.
- regular monitoring . You will always get the correct information about the current status and battery status.
- Prompt Warning . warning system works automatically, so you never forget that it is necessary to charge the battery.
- Modularity . Simarine monitors have a modular structure, in addition to the basic description sets 7 interchangeable and complementary units able to control up to four batteries.
Among other features Simarine marine monitors are the following:
- reflect the percentage of the battery
.- Calculate the battery life
.- reflect the state of the power supply charge
.- uses a special algorithm that assesses the level of deterioration of batteries
.- Easy remote access via a mobile app
.Available kits
The company offers several different ready-made sets that consist of just a monitor and a set of sensors.
BASIC SET
- The current measurement of consumption (up to 300A).
- Control voltage 2 batteries.
- Up to 2 of the fuel level sensor in the tank.
- For 12V and 24V systems.
STANDARD
- Control voltage 4 batteries.
- Up to 4 fuel level sensor in the tank.
FULL SET
- The current measurement of consumption (up to 500A).
- The measurement of consumption, up to 4 devices (at 25A).
Available for installation of measuring shunts and modules
The modular system requires the ability to connect to the monitor modules of different shunts and measuring various parameters. In particular, the following options are available:
SC301 -active shunt monitor PICO battery 1 has a voltage sensor 1 and the temperature sensor 1, the current to 300A. Designed for installation in systems with voltage up to 75.
SC302T -active combination shunt PICO has two sensor voltage detection 2-temperature and fuel and one current sensor 300 A is suitable for systems with a voltage up to 75 V
.SC501 -active shunt monitor PICO battery 1 has a voltage sensor 1 and the temperature sensor 1, the current to 500A. Designed for installation in systems with voltage up to 75.
SC502T -combined high precision shunt monitor PICO battery 2 has the voltage detection sensor, 2-and fuel temperature and the current sensor 1 to 500 A is suitable for systems with a voltage of 75 V.
ST107 -this is the perfect digital module that provides extensive connectivity and monitoring. It allows to control the fuel level sensor 7 in the tank 3 and 4, the battery voltage temperature.
SCQ25 -innovative module for monitoring the individual consumer and the generator 4 of current sensors 25A to each. Suitable for systems with an operating voltage of 12 V and 24 V. It is able to monitor the status of up to 4 external user (freezer, tools, lights, etc.). This monitor 4 can be connected to similar modules.
SCQ25T -is an innovative combination of a shunt, fuel control system in the tank and voltage monitoring unit with a wide range of monitoring and control capabilities. It allows to control the fuel level sensor 7 in the tank 3, battery voltage, temperature, and 4 to 4 external user (refrigerator, lighting equipment, tools and others.). This monitor 4 can be connected to similar modules.
In the online store you can 130.com.ua buy a battery status indicator Simarine in Kiev, Odessa and Kharkov with delivery across Ukraine. In addition, you can purchase additional shunts and accessories for them.
Related materials
