Design features and operating rules for car vacuum cleaners
The power of a car vacuum cleaner that runs on the cigarette lighter is limited by a fuse in the cigarette lighter circuit: the 12 V socket in the car cannot connect high-power devices, usually a 15 A fuse is installed there. Most often, the power of the car vacuum cleaner is limited and does not exceed 100 watts, that is, it consumes about 10 amperes of current. Of course, this is about 10 times less than the power of household vacuum cleaners connected to a 220 V network.
That is, it is obvious that with such power, such a device is not suitable for removing very strong pollution. The main purpose of car vacuum cleaners is to keep the interior clean. It does an excellent job with fresh dirt, no need to wait until the sand and dirt are absorbed into the coatings. For complex stains, you will need to order professional cleaning. It is in order not to spend money on it and prevent ingrained dirt that a compact car vacuum cleaner is suitable, which easily removes freshly poured sand from rugs or crumbs from the surface of the seats. Let's look at the features of the operation of such devices.
How does a car vacuum cleaner work?
Most models function in the same way as conventional household vacuum cleaners. When switched on, the electric motor starts. Through the inlet, air is sucked inward, along with it, dust, dirt, crumbs and other contaminants are sucked in. According to statistics, the time of continuous operation of such gadgets is 20-30 minutes. This time is enough to clean the car interior
Where does the collected waste go?
Most modern car vacuum cleaners have received a bagless dust collection system. It is convenient and practical, no need to change and clean the bags. The dust collector is attached to the body, and since vacuum cleaners of this type are very compact, the volume of this compartment rarely exceeds 1 liter. For ease of use, the dust collection compartment is made of transparent plastic. And the motorist, as it fills up, knows exactly when to empty the container. To do this, just press the button and disconnect the container and throw out the dirt and dust from it, and then return the container to its place.
How does the filtration system in car vacuum cleaners work?
The cheapest models usually have one filter, it is able to trap only large particles, preventing them from returning to the cabin. In more advanced vacuum cleaners, a double system is used, which also implies the presence of an additional filter designed to protect the engine of the device from the ingress of fine dust particles. This allows you to increase the working life and minimizes the risk of breakage of the main structural elements.
The most modern models, as a rule, already have a triple filtration system; in addition to two filter elements, they also have a special fine filter. Thanks to him, up to 99% of all sucked-in dust is retained, that is, even the smallest particles will be inside and will not return back to the cabin.
What kind of dirt can a car vacuum cleaner handle?
This type of device is designed to collect small dry debris, sand, dust, crumbs, wool, small candy wrappers, etc. There are also models of car vacuum cleaners that can suck up liquid. This option expands the capabilities of the instrument. With their help in spring or winter it will be possible to clean the mats from melted snow and wet dirt. They will also help to quickly get rid of drinks that have been spilled on the seat.
How to choose a power model?
This is a very important point to consider if you are planning to buy a car vacuum cleaner. Power determines depending on the pollution that you plan to clean. If there is not a lot of garbage and dirt in the interior of your car, that is, frequent cleaning is not required, then even a not the most powerful model will do - 30-50 watts. Such a device can easily cope with minor pollution and remove dust.
It is a completely different case when every day it is necessary to remove animal hair, crumbs and other debris. This is true for pet owners and parents of young children. Here it is recommended to choose a model with a power of 75 watts. These vacuum cleaners are characterized by high suction power. They easily cope with the dirt of almost any complexity. However, it is worth remembering that more power means more energy consumption. It is important to find a balance between power and consumption.
Which model is better with or without a hose?
It's very individual. Much depends on the frequency of cleaning, the size of the cabin and the availability of storage space for the car vacuum cleaner. Hoseless models have the advantage of being compact and easy to store, but often you will find it difficult to get into tight spaces, such as when cleaning under car seats. Models with a hose are more practical, a flexible hose can crawl even into hard-to-reach places. In addition, the device can be put and not kept on weight. Now manufacturers often offer models with a removable hose, which is convenient and practical. And also many vacuum cleaners have a special nozzle for cleaning in cracks. Therefore, at pay attention to the complete set of a particular model.
Where else can you use such a vacuum cleaner other than a car?
The scope of use of car vacuum cleaners is limited only by access to a power source. If you have a wired model that connects to the cigarette lighter, then you can only clean in the cabin, where the wire can reach.
The most versatile are battery models, they are not tied to the network, so they can work almost anywhere. Such vacuum cleaners are very useful in everyday life. With their help, you can quickly remove crumbs from the floor or animal hair from the sofa when it is inconvenient to get a large vacuum cleaner. In addition, these compact devices can be taken with you to the country house, hiking, picnic, etc. The only thing to remember is that the operating time of such devices is limited by the capacity of the battery. But they are enough to remove small contaminants along the way.
If you want to buy a car vacuum cleaner in Kyiv, Kharkov and Odessa, then in the online store 130.com.ua you will find a large selection of models with delivery in Ukraine.
Related materials
Car vacuum cleaners: Best Sellers
