Noise isolation of the car. Dangerous mistakes.
At first glance, it seems that noise insulation is a simple process. And what is difficult? It is necessary only to disassemble the salon, glue the material and back to collect everything. After considering all the nuances, you decide to do it yourself. This is good and even commendable, but consider the possible errors:
Timing. The whole process will take several days. Professionals cope faster because they have the necessary experience. You also have to do everything yourself and not always everything will be obtained from the first time.
Scratches. Use a tool made of plastic, it will not leave scratches on the surface during the parsing of the cabin.
Breakages during dismantling. During the parsing, it is very easy to damage the fastening mechanisms. And you can not replace them later. So do everything neatly, in advance, review the tricks and nuances of parsing specifically your car.
Unprepared surface. You need to prepare a cabin for installing materials: remove dust, dirt, corrosion, old vibration isolation.
Installation is not there. You must decide in advance what will be installed in which place. Remember that the ventilation holes and stiffeners can not be sealed..
Traction. The gluing of the material is by far not the most important stage. Particular care must be taken during the rolling by a special roller. You need to prevent the occurrence of air bubbles.
If you consider these facts, how to study all the information, then the noise insulation with your own hands will be successful. And the experience gained to the car owner never hurts.
At 130.com.ua you can buy sound insulation in Odessa, Kharkov and Kiev you can on 130.com.ua delivery in Ukraine.
See the video reviews of noise isolation
Noise insulation: Best Sellers
