Security systems AJAX
Agree, it is interesting to observe what new solutions appear in the «Made in Ukraine» segment. One example of such products is the wireless security system Ajax. And this device in 2018 has every chance to become the best in our market.
In addition to the basic elements, the standard equipment includes everything necessary for installation: self-tapping screws, dowels, fasteners. Of course, such care for customers is respected. Another plus in the bank of the advantages of the brand is the pre-installed sim card Kyivstar or Lifecell.
Basic components
Depending on the configuration, the security system may include certain structures. Let's consider the features of each.
Ajax Hub - the brain of the device
The hub is a key element of the whole system. To activate it, you need to open the back cover, connect the power cord and network cable, connect to the network and the router, and press the power button.
As indicated in the manual, the GSM channel is used as a backup, so you need to think about the location of this element. Restrictions are only in the length of the cable. But in principle, due to the elegant design, the design can be placed anywhere.
Ajax MotionProtect - motion sensor
The most overall element in the system, but it's quite easy. Has 3 degrees of sensitivity, due to which you can fine-tune the system, for example, avoiding the reaction to pets.
In the installation, too, there are no restrictions: you can install on a flat wall, at an angle of 90 degrees. In the application, after installing the sensor, all information about this element will be provided. Of the features - built-in thermometer. First it causes surprise, and then you realize that this is the right function. In addition, the battery status, signal strength, and sensitivity are displayed.
Ajax DoorProtect - sensor for opening windows and doors
The magnet and the sensor detect each other even at a distance of 2-3 cm. The manufacturer recommends the following mounting scheme: sensor - fixed part, magnet - movable.
In the mobile application, you get the same data list as in the case of a motion sensor. In addition, the state of the door is indicated.
Ajax SpaceControl - keychain for controlling the alarm system
The keyfob repeats the same functions as the mobile application. You get 4 buttons for:
- inclusion of protection;
- disarming;
- inclusion of partial protection;
- alarm button for call-out of employees of security agency.
This element can be reprogrammed to control the mechanisms of the "smart house", if it is necessary for the user.
It feels like the key is very nice, the plastic does not slip in the hand. The range is impressive - up to 1000 meters in open terrain.
Presetting
To get started, you need to register with the system through a mobile application. In general, the whole process includes the following steps:
Create an administrator. It can be changed in the future in the settings. So, you need to specify mail, phone number and set a password.
Adding a hub to your account. Think of some name for it, for example, "apartment" or "summer house". Next, you must provide a serial number. You can do this manually or scan the QR code from the package.
Adding rooms to the system. It is necessary to add all the rooms that will be protected: you can add titles and even photos.
Consecutive addition of all devices by the same principle.
Adding users - the rest of the family or employees. To do this, you specify the mail to which the invitation will be sent.
In general, the mobile application is very understandable and simple. Will understand even the one who is with the technique of "You".
Features and benefits of the system
Simple management of a complex system
Ajax is a modern device developed with the use of all innovations. For some, it may seem difficult, but in practice - everything is very simple. To put or remove a room from the guard, enough just a few clicks in the application.
Skillful combination of components and technologies
The advantage of the security system is that a completely new approach was taken for the "base," the device was developed from scratch. The manufacturer connected the best, but at the same time affordable components, placed them in elegant cases and combined them with new technologies. In the end, we received a truly worthy Ukrainian product.
Powerful and stable communication
Jeweller - wireless technology, which is not inferior to the level of reliability even modern wire connections. It connects all components at a distance of up to 2 km. All signals have a unique encryption system. If an attacker tries to hack it, the device gives an appropriate alarm.
Protection against failures
In the event of a power failure, the product will continue to operate with a backup battery. If there are problems with the router or the provider, the security functions will continue to work with the backup GSM-channel. In any case, if an attacker tries to break the system, it will continue to work and at the same time will give an appropriate signal to the user.
Protection against false positives
Under normal conditions, the security device works identically. But this is an ideal world, which in practice turns out to be completely different. In reality, we get drafts, noise, radio interference and other distractions. Ajax technologies are designed with these conditions in mind and therefore can guarantee uninterrupted protection even in this case.
Buy security systems in Kiev, Kharkov, Odessa at 130.com.ua with delivery to Ukraine.
To sum up
The first impression is a glamorous body, but after the first experience with this element, you understand how many technologies this design includes. In addition, the functionality of the standard configuration can always be expanded by installing additional modules and sensors.
This is one of the most worthy decisions of 2018 from the "Made in Ukraine" segment.
We recommend:
Watch a video overview of AJAX security systems
