Overview of the Pioneer FH-X730BT
Usually, for a model of the head unit in the amount of 2DIN means multimedia devices. Of course, on the big screen everything looks better and more attractive, but what if the priority is a quality sound, and not another functional?
The car stereo FH-X730BT though has a 2DIN size, but it's not multimedia. Instead, it offers high quality sound. Its main difference is that with its help it is possible to build in a car in addition to the usual acoustic system, also a per-channel system with delays.
Features of Pioneer FH-X730BT
The device has a unique, but recognizable design: glossy panels, the lack of excess gives the model an expensive look. On the gloss, the fingerprints are not as visible as expected, but to the dirty hands this coating is still particularly sensitive.
Pioneer's head unit keyboards are easy to use: a large-size volume control encoder, other control buttons are located freely. The character screen is quite large, which is a special advantage. You can independently adjust the desired color of the backlight, and for the screen and buttons to choose different shades.
With the Bluetooth wireless network, you can simultaneously connect 2 smartphones at once. The module also has an extended frequency range for voice transmission.
Using USB, you can connect devices Apple and Android, and with the latest smartphones you can listen to music, as with a conventional drive. Pioneer FH-X730BT supports files in FLAC and Hi-Rec format. Buy car receiver in Kiev, Odessa, Kharkiv with delivery to Ukraine can be at 130.com.ua.
Channel gain
The first time you connect, you need to select the "Standard" or "Network" mode. The second option — this is the way to accouter acoustics: four outputs are used instead of front and rear, outputs to midbass speakers and tweeters. Note that the speakers are connected directly, without a crossover. Instead, it operates a high-pass and low-pass filter.
Note that the RF filters pass all that above the specified frequency and, conversely, weaken anything below it. And the low pass filter misses anything below the specified frequency. This principle allows you to smoothly adjust the sound, and you can achieve even better quality than in the case of crossover.
The network mode menu provides the ability to set filter frequencies within 1.25-12.5 kHz. Such parameters are enough for classical systems and for hands-free, professional acoustics.
You can also change the slope of the filter — a parameter that determines how much the signal will be attenuated out of the filter's bandwidth. But do not immediately set the highest value, sometimes the best quality can be obtained with minimal values.
In the "Standard" mode, filters are also available, but their ranges are very limited: 50-200 Hz.
Time Alignment
With this sound function, you can set the signal delay for a few seconds in each channel. This feature will allow you to equalize the distance to the speakers and to ensure that the sound is propagated evenly.
The Pioneer FH-X730BT settings do not require any special knowledge: just select the listening point and the acoustics itself sets the delay parameter.
Equalizer
Here we have 13 bands for individual sound settings. So, we can get rid of all the problems and acoustic features of the salon. If you can not adjust the parameters manually, use several predefined options.
Smartphone Management
You need to install a free, official Pioneer ARC application: it is available on Google Play and the AppStore. The desired mode of operation is set in the CD-receiver menu and now all control functions are available in your gadget.
In multimedia models, this function is less popular, because everything can be done on a convenient screen. But for devices with a character display, such an option simplifies the sound setting.
Pioneer FH-X730BT offers us good sound capabilities: sound settings, powerful equipment, work with smartphones, support for FLAC. All these characteristics - an occasion to consider a model for its installation in your car.
Related materials:
Car stereos: Best Sellers
