Pioneer AVH-190 and MVH-AV190 — overview
These two models are very similar to each other. But, as you can guess by name, one of them has a disk drive, the other — no. Both devices belong to the initial rulers and therefore have only a basic functionality. In this and their advantage: all the most necessary, without unnecessary features, which are often never used.
Moreover, Pioneer's concept of "base" invests much more opportunities than its competitors. This also applies to audio settings. But about everything in order.
What's so special about these models?
Working with sources. In principle, as in any other models with a screen, there are inputs for connecting a rear view camera or other devices: you want — a player, you want — a game console.
Own sources. Well, radio is really quite a standard feature and it's not necessary to even mention it. Let's talk about other functions. The MVH-AV190 can only work with USB-media, but the AVH-190 can still spin discs. The latter can be appreciated by parents, since you can include a DVD with animated cartoons for your children if the trip is scheduled for a long time. And then it is important to connect external monitors.
As for USB, then besides the standard MP3 and WMA, it also supports AAC and uncompressed WAV files. Since in such devices video formats are far from being a priority, then things are a little worse. But files with low bitrates can easily reproduce.
Ergonomics. It always sets the tone of the screen. But with this, the AVH-190 and the MVH-AV190 have no problems at all. So, we get a very responsive sensor — you do not need to press the button or "finger" the display several times. The screen responds to a slight tap quickly and does not slow down.
The quality of the picture also does not lag — bright and juicy colors, impressive viewing angles, high resolution.
Sound. It is immediately evident that these devices have everything necessary for a classical audio system. It can be either with separate amplifiers, or without them. In the latter case, there is a "bonus" from the manufacturer, which many people forget or even do not know about. This is the ability to connect the subwoofer directly, without the rear speakers. The operating mode of the latter switches to the menu.
Of course, immediately reject the fantasy of connecting "heavy" sabs with low sensitivity. Built-in amplifiers are simply not designed for this kind of load. But this feature is perfect for 6x9 speakers. In this case, you can get a quality and interesting sound.
If a sub is connected, it can be adjusted, for example, to adjust the signal level, its polarity and the frequency of the low pass filter. On the main filters you can connect a high-pass filter — you can limit the lowest bass, thus not allowing the speakers to be overloaded.
In addition to the standard sound settings, here got a 5-band graphic equalizer. For earlier devices, this possibility can be considered very advanced. You can separately adjust the bass level, for example, when you want to add "weight" sounds, but leave the whole sound unchanged.
You can also note the ability to expose relative source levels, because sometimes such a functional will be very useful.
So, despite the fact that the models belong to the initial class, we got very impressive opportunities. We summarize all of the above — convenient and simple control, good display, responsive sensor. Here we add the necessary sound settings and get the optimal solution for choosing a new head unit. With or without a disk, the choice is yours.
Buy car receiver in Kharkov, Odessa, Kiev with delivery across Ukraine is possible on the site 130.com.ua.
Products from the review
Related materials:
Car stereos: Best Sellers
