Kit Review: head unit Pioneer SPH-T20BT plus tablet SDA-8TAB
In this article we tell you about a unique set of Pioneer, which consists of a head unit SPH-T20BT and external removable plate SDA-8TAB. It is an advanced multimedia system, which undoubtedly opens new dimensions in the approach to the creation of new automotive head units. In this article, we will discuss the features and the main thing the main features of this system, which has already become one of the revelations of 2020.
Unique multimedia solutions for modern drivers
With the emergence and rapid development of mobile devices as a popular source of media content from their union was only a matter of time automotive head units. One of the first Pioneer's such experiments was head unit Pioneer SPH-10BT. Engineers for the first time handed over the management and transmission of visual information, a smartphone, and the radio remained only the main basic functions.
But the company decided on this do not stop, the result was a unique set, which combines media receiver SPH-T20BT, mount plate and in fact he SDA-8TAB tablet.
The uniqueness of this solution lies in the fact that the tablet is fully functional and is not attached to the radio, that is, it can be used outside the car as the most common tablet computer. Available fairly broad functionality: listening to music, watching movies, correspondence by e-mail or instant messengers, browsing web pages and much more.
Let's talk more about the features and technical capabilities of each component individually.
Tablet
The plate has an 8-inch capacitive touch screen with a resolution of 1280 x 800 pixels, the device operates on the operating system Android 9 Pie. Processor Cortex A7 QuadCore 1,8 GHz, RAM is 2 GB, and a built-16 GB. It is also worth mentioning that there are two cameras (0.3 megapixel front and rear 2.0 MP). Supports transfer via Wi-Fi and Bluetooth data. The plate also has a connector for connection to the head unit disposed on the back side.
Users can easily download and install all the necessary equipment for his work or entertainment applications: social networks, instant messengers, video streaming services, navigation software, and more. That is, the tablet can be adjusted for any personal needs and the needs of the driver.
Please note that on the plate already loaded the basic most popular among users of Google's applications, and available business Pioneer SmartSync application that allows you to change the backlight control Bluetooth and radio, display interface parking radar, as well as easy and quickly adjust the sound settings.
The head unit
The head unit SPH-T20BT has 2DIN size, it can be easily installed inside the car. To connect an external audio equipment, there are three pairs of RCA line outputs. It is also fitted with a built-in MOSFET amplifier type sound output of 4 x 50 watts and a sound processor that delivers very high quality playback and flexible sound adjustment.
To fix GU tablet equipped with a special bracket with two connectors: one to connect the tablet-on the front side, and the second to connect to the radio-at the back of the.
The front panel on the recorder has a special cable to connect the short attachment. After connecting bracket further fixed to the front panel recorder screws.
As for the available slots, then there is enough of them. On the rear panel:
- antenna jack,
- connector for PDC Pioneer ND-PS1 (option not included),
- Block power and acoustics,
- mic input and steering buttons adapter.
- USB connector,
- input for rear view camera,
- output for connecting a monitor passenger.
If the connected parking sensors and a rearview camera, then when making maneuvers, reversing signals PDC sensors, and video from the parking camera will automatically come to the plate. This will significantly simplify the parking and movement of the machine backwards, as on a large 8-inch screen, the driver is all very well seen, and parking sensors will warn of further approximation to any obstacles.
Features Interface
All settings and control the devices by brand Pioneer SmartSync application. When you first start should definitely be connected through to the base plate using the Bluetooth channel. Then the connection will take place every time you switch to automatic mode.
The settings menu is quite simple and convenient. You can manage all systems and connected devices. For example, using the parking aid can be controlled rear camera and parking assistant, to establish their operation, including to set up automatic switching. You can use any parking camera. control program interface is very simple, everything is intuitive and user friendly. All units settings are conveniently grouped by purpose, so the desired parameter can be found quite quickly, even if you see the menu for the first time.
As can be controlled via Bluetooth, it is not necessary to connect the tablet to the radio through a wire-the device may work fine anywhere in the cabin. In fact, you can use the tablet as a remote control. The driver in this case will be available buttons in the mounting bracket.
Here is installed a modern digital radio, there are 3 options available signal processing: RDS, manual and automatic station search. In addition, you can select multiple frequency ranges, including the combined long/medium-wave. When the radio is turned on, it is possible to see a list of preset stations in the lower row. A total of 3 of the storage unit 6 under stations-2 1 FM and AM. On the right, in the corner you can find an extended list of available radio stations with names. It is very convenient and you can quickly switch between stations.
adjust the playback system is also digital. For all structure classical, in "Front-rear-a subwoofer," there is a built-in EQ, time alignment and crossover
Settings menu Audio -everything is very clear, especially to those who had already had to deal with Pioneer's radio cassette player, everything is standard, almost like all devices of this brand.
EQ -here there are 7 preset options, and you can save up to 2 sets of custom settings. Note that the user can choose to use any EQ: three-band simple or more advanced 13-band.
SuperTodorokiSound -this item in the menu refers to the special bass processing functions. It allows for a more powerful and rich sound at lower levels. This feature is available during settings in the EQ settings, you can choose just one of the options of music playback.
Three levels of loudness -a standard feature for Pioneer stereos, all done as comfortably as possible, you can change the settings with one touch, as well as reset the settings to the standard.
DynamicBassEnhancer -this is an optional feature that by harmonic synthesis LF signal creates in the listener the illusion of a powerful bass.
SoundRetriever -This feature allows you to work longer with HF, has 3 levels of processing and allows you to restore the sound of compressed files. As a result, at the top it is possible to achieve a cleaner and sonorous sound.
EasySoundFit -a function for quick setting of the sound field in the cabin of the machine based on the type of the vehicle body. Note that the signal level of the speaker is installed immediately, and to adjust the crossover and speaker distance you need to select the listening position. For example, if you drive a classic car, in which the steering wheel is on the left, then it is necessary for the driver to choose the position FRONT R. After that, the settings should be available for the initial basic set of body distances to loudspeakers. The user can either leave them or to disable delays at all or set your own values. Please note that for the position "front" and "All" option is not provided by the manual setting of time delays, available only the average.
In the settings for the user can set the front and rear cut-off frequency of high-frequency and low-frequency filters, and adjust the slope of the roll-off. Thus filters for the left and right speakers are adjusted synchronously, and the parameters for the front and rear independently adjustable. All filters are easily turned off if you wish.
Supported file formats: the head unit can be operated with all major audio formats, with sound for WAV and FLAC the output is just fine, however, and compressed formats with high bitrates, practically will not give in to them. Also worth noting is that the device also supports all of the major and most common video formats: MPEG1/2/4, AVI, FLV, MKV. If necessary, the user can expand the capabilities of the device, it is sufficient to install additional any application that will read the desired format, which is not present in the normal list.
Summing up
Set Pioneer STH-80BT combines the most advanced technology in the field of automotive electronics, this multimedia system is easy to satisfy all needs of a modern driver and his passengers because supports a large number of advanced features and provides wide opportunities not only for listening to music and watching videos. With the ability to use the tablet autonomous control system it is very easy and convenient. The tablet can be used alone as an ordinary gadget.
This is a great car radio with clear sound and full with the latest multimedia functionality, which has been specially designed to meet the needs of users who do not represent life without mobile gadgets.
Sound even with built-in regular amplifier without connecting an additional amplifier turns juicy and bright, and thanks to the wide possibilities for customization and digital audio processing can be done just perfectly sound tailored to personal preferences of listeners. Due to the presence of three pairs of RCA outputs, if necessary, the car owner can supplement the acoustic system in the cabin external amplifier, connect the speakers, subwoofers and other audio equipment. An open platform and the Android operating system allows the user to install any applications that may be useful for entertainment and work.
In our online store you can buy radio Pioneer SPH-T20BT with tablet SDA-8TAB in Kiev, Odessa and Kharkov at a good price with delivery in Ukraine.
Related materials
Car stereos: Best Sellers
