News from Ajax-what to expect from the company at the end of 2018-the beginning of 2019?
In the near future we can expect the release of new, more improved and automated security alarms for the house from the company Ajax. With them, it will be much easier to provide protective functions both indoors and outdoors. In addition, now it will not be difficult to ensure security in large areas and in rooms with several floors. An important update will be the ability to find out via SMS notifications about the activation of the alarm and the reason for its triggering. We present some systems and solutions for more information.
New from Ajax
Ajax Hub Plus
Hub Plus is an excellent security device, equipped with an increased memory with a classic design of the Hub model and a power supply unit equipped with the Hub Plus. Thanks to this function, power is supplied directly from the mains, without using a power outlet.
This model has the following connectivity options:
  • WI-FI;
  • Ethernet port;
  • slots for 2 SIM cards;
  • Support for 2G and 3G Internet connection.
By using a WI-FI connection, the Jeweller's communication distance increases, since there is no interference from the Ethernet cable. In addition, the ability to connect via the mobile Internet provides greater reliability, since the loss of 3G connectivity is accompanied by reconnection to a 2G connection. If the situation does not improve, then the second SIM card is activated. The whole process takes no more than 4 minutes, which is much less than in other devices, they perform it in 17 minutes. Therefore, this system is the best and best option for the installation and protection of the cottage or home in the country.
Longer Hub Plus operation is possible due to the presence of a backup battery. It also makes it possible to connect more users, group items or devices. The 2-fold increase in memory provides an opportunity to fully learn about the features of this modern “Smart Home” system.
New from Ajax
Ajax Socket
This device is a smart, wireless controlled socket, does not require additional settings. It is simply connected to the hub, and it can fully perform its functions, namely, to control the power supply of the device that is connected to the network.
Each model has an LED backlight that shows the power consumption of the monitoring device. If the indicator is very close to purple, the more energy will be used.
Also, each outlet has a protective system, thanks to which protection is provided against instrument burnout in the event of a voltage change. In addition, the connected device will not be able to melt even with prolonged use with a sufficiently high load. This factor is important because this problem is one of the most relevant not only for smart, but also for ordinary outlets.
New from Ajax
Ajax Button
Ajax Button is a compact button-switch that is attached under the table top or on the bed, at the head of the head, and can also be worn with a key ring or just in your pocket. The main thing is that it should be close to the user. Use Cases:
  • Alert Button . This will call your security organization’s rapid response team;
  • Call for help . Use in this case will help to quickly call for help for the elderly or sick people;
  • Manage your Ajax system . In this case, the button is programmed to perform various functions with a long or short press.
The button has the function of two-way communication, and the light display notifies about the successful transfer of the task to the hub and its implementation. She always remains in active mode, it does not need to be activated by pressing.
Ajax MotionProtect Outdoor
MotionProtect Outdoor is an ultramodern wireless outdoor motion detector, which is the first device in the series of equipment to perform the protective functions of the local area. Thanks to innovative technologies that are combined in this device, it will not respond to pets, foliage and other minor interference. This device is fixed only by finding a person in the protected area. This system is equipped with an intelligent LISA system that eliminates false inclusions.
Since such cases occur more often outside the premises, the Grade 3 anti-masking system is additionally equipped here. With its help, the possibility of overlapping the view using different methods, painting the lens or hanging it with a cloth is more than excluded.
A clear advantage of MotionProtect Outdoor is the ability to ensure the security of vast as well as small territories. Movement detection distance is from 3 to 15 meters.
New from Ajax
Ajax MotionProtect Curtain
The creation of hidden obstacles with the possibility of unimpeded movement around the protected area is possible thanks to the MotionProtect Curtain motion sensors or simply “curtains”. With their help, it is possible to detect the movement of any objects at a distance of 8-10 m from the protected area. The system also has similar functions with the previous device:
  • lack of response to pets and other natural interference;
  • having an intelligent LISA system;
  • has a tempera defense;
  • Grade 3 anti-masking system.
In addition, they are equipped with a special system consisting of 2 pyrosensory elements, mirrors and lenses. Thanks to this set of functions, the sensor does not work for normal and false interference, ensuring full protection of the protected area.
Ajax ReX
The current version of the RangeExtender, a device called ReX, makes it possible to significantly expand the covered area for Jeweler radio communications. This allows you to use these systems on large objects-industrial or office premises, as well as in hotels, shopping centers and other buildings.
Ajax MotionCam
The MotionCam Wireless Motion Sensor is equipped with a feature that captures events using photos. The camera is activated only in the event of a triggering and captures an event with a snapshot, with an extension of 320x240 pixels. Works well in any situation, even with poor visibility will be able to signal that unauthorized entry occurs.
To get autonomy with this device, among other security systems of this manufacturer, the developers did the impossible-an innovative Wings-radio protocol was developed. With it, the signal is transmitted for 150 ms, which is the well-known standard of the manufacturer. You do not need to have a good internet connection to become aware of an alert. At the same time, autonomous abilities and range of operation are not lower than those of other Ajax devices. Pricing will also not be much different.
API
The API will help to integrate all Ajax devices and equipment that are used by large enterprises or companies that have a huge number of objects in service. It will be possible to integrate them into their own software systems in order to administer them directly and without using different applications and other software.
Hub OS Malevich 2.7
Updating the system using Hub OS Malevich 2.7 will be much faster and easier, in addition, it will provide an opportunity to use new and improved features of the systems. This improvement will allow exchanging information not only via the Contact ID protocol using the Ajax Translator, but also directly using the SIA protocol. This digital encrypted standard makes it possible to transmit information about events and other additional data. This may be information about the time of the incident and the location of the object.
New from Ajax
Monitoring in Ajax PRO Desktop
The emergence of a new option to monitor the object provides many opportunities for use. The application is used as a console software for security organizations, remote monitoring of residential buildings locally, as well as monitoring of business centers and shopping complexes. In total, you can administer up to 1,000 Ajax system devices.
Advantages of this application:
  • quick and easy connection of the security system to the surveillance;
  • providing sufficient data on a single device and its status, as well as the ability to configure remotely;
  • having the option to set up receiving events about events.
Thus, Ajax will introduce innovative, previously unreleased equipment and solutions to obtain enormous opportunities to ensure the security and full protection of the protected object or territory. Most models of equipment will be presented in the 4th quarter of 2018, the rest-in the first quarter of 2019.
The protective system "Smart Home" is the necessary equipment to fully protect your site or country house. The presence of this device will allow you to be completely confident in its safety. home alarms in Odessa, Kharkov and Kiev at 130.com.ua with delivery to Ukraine.
Materials on the topic
