Is the engine oil suitable for the gearbox
Many car owners often think about whether it is possible to use engine oil for the gearbox. In domestic cars, indeed, one oil was used for the engine and transmission. The reason is that they did not yet make the appropriate composition for the checkpoint. Transmission lubricant at that time had a high viscosity, which caused a large load on the synchronizers of the device, thereby increasing the wear of parts. But oil for the engine in its characteristics is better.
But since then, the manufacturers have perfected the technology and developed a unique composition that is suitable for the gearbox. Each product is intended to solve a specific problem. Here it is also necessary to take into account further operating conditions.
It is not recommended to experiment with oils and use them for other purposes. After all, so the details of the CPR can quickly wear out.
Motor and transmission oil: what's the difference?
The composition and function of each oil is different. Motor and transmission oils have their own characteristics, because their purpose is not only to lubricate individual mechanisms. They have a mineral, synthetic or semisynthetic base, as well as additives. The latter differ from each other and may even damage the mechanisms if they are used inappropriately.
Main differences:
- different temperature range for operation;
- viscosity parameter;
- presence of additives: their number, type.
Lubricating fluids for the motor guarantee the stable operation of this unit due to a suitable composition. This product is used taking into account engine characteristics. Therefore, when selecting, it is necessary, first of all, to be guided by the recommendations of the manufacturer of your car.
PPC is a complex mechanism that is characterized by high temperatures during operation. The viscosity parameter of the engine oil can not guarantee the necessary functionality of the device. In addition, the transmission needs lubricants that are not included in the engine oil.
The main task of the gearbox oils is to reduce heat during the operation of the mechanism, to minimize the noise level, to prevent premature wear of individual elements. The gearbox oil operates under constant load conditions, while the motor fluid functions under different conditions and under different conditions of use. In addition, the life of the oil for the gearbox is much greater.
Transmission and motor lubrication: how to distinguish
First, pay attention to the viscosity index: for transmission fluids it is much higher than for motor fluids. Choose the product you need, focusing on the type of device. For example, the fluid for the manual transmission and for the automatic transmission will differ in composition.
Determine the composition only by the appearance of the liquid is almost impossible. Only an experienced mechanic can handle this task.
There is one proven method - to add oil to a container of water. If the form is held, it is a lubricant for the engine, and if not - then for the transmission.
And what if you fill engine oil in the checkpoint?
Here you need to look in the recommendations for using the car. Some vehicle manufacturers allow the use of engine oil for the gearbox. However, if this is not provided, then the wear resistance of the mechanisms will deteriorate considerably and, consequently, the service life will be shortened. And this is at best. If you use unsuitable oil constantly, the gearbox may fail.
At 130.com.ua you can buy motor oil in Odessa, Kharkov and Kiev is available at 130.com.ua with delivery across Ukraine.
Remember that different compounds can not interchange each other, mix. This replacement is allowed only in an emergency situation: if there is no gear lubricant at hand. But this is only a temporary solution and you need to get it as soon as possible.
