Marine acoustics for boats, yachts and other swimming facilities
Traveling in the sea, I want to get the same comfortable conditions as on the car. Fortunately, marine acoustics are not far behind car systems and allow you to enjoy your favorite music even in such conditions.
Using the radio on the ship requires compliance with certain conditions. For example, acoustics are made of special materials that are resistant to moisture, the effects of salts and constant solar radiation, are not subject to corrosion, are resistant. At the same time, it should produce a great sound.
Quality Acoustics Overview
Consider all the nuances of marine audio systems on the example of popular devices.
A radio tape recorder for a yacht is a typical device that, according to external data, resembles a model for a car. Standard-removable front panel and CD-connector. These receivers put the following requirements:
- protection against mechanical impact;
- high water and dust resistance;
- quality sound.
Marine recorders are notable for expanded functionality: here you can also adjust the power of the subwoofer, adjust the high-pass filter, the equalizer. You can connect gadgets and play music from them. Ports are available for integration with other devices, LCD display. Comfortable to use even with strong pitching, ideal for small craft. Buy the marine acoustics in Kiev, Kharkov, Odessa at 130.com.ua with delivery in Ukraine.
In general, manufacturers offer a wide range of marine speakers and optional devices. For example, the Alpine MC-20 remote control for Marine models or the Hertz HCP 2MX Marine amplifier with a nominal power of 120 watts per channel.
Optional accessories are also designed to create visual effects.
Due to the fact that marine acoustics is presented in a wide range, you will not have any restrictions in its use, even for use in maritime transport.
Materials on the topic
