Alarms Magnum GSM 8xx-comparison of keyfobs
No.
The main parameters of security systems |
820
822
825
860
880
880C
1
Maximum number of supported keyrings |
4
4
4
8
8
8
2
Protection against intelligent hacking of radio code |
is
is
is
is
is
is
3
Protection against unauthorized training of key fobs |
is
is
is
is
is
is
4
Sending messages while training the system to keyfobs |
is
is
is
is
is
is
5
Integrated two-way CAN-module (produced by TEC) |
is
6
Integrated GSM two-way communication module |
is
is
is
is
is
is
7
Automatic control of critical fund balance |
is
is
is
is
is
is
8
GSM-signal level control |
is
is
is
is
is
is
9
GSM-channel monitoring |
option
option
option
option
option
option
10
GPS module |
option
option
option
11
Location control via USDD service |
is
is
is
is
is
is
12
System programming via PC (USB-2.0) |
is
is
is
is
is
is
13
Phone programming via programmer |
is
is
is
is
is
is
14
Keeps in memory the last 16 shots |
is
is
is
is
is
is
15
Voice Messaging |
is
is
is
is
is
is
16
Sending SMS alarm messages |
is
is
is
is
is
is
17
Quickly turning off and on messages |
is
is
is
is
is
is
18
System management via GSM communication |
is
is
is
is
is
is
19
Direct control from registered phones |
is
is
is
is
is
is
20
Banning control from unregistered phones |
is
is
is
is
is
is
21
Control of entering a personal code from other phones |
is
is
is
is
is
is
22
Emergency disarming without charm and telephone |
is
is
is
is
is
is
23
Emergency arming without key fob and telephone |
is
is
is
is
is
is
24
Service mode of the system |
is
is
is
is
is
is
25
Number of inputs (of which are universal) + CAN |
11 (4)
11 (4)
11 (4)
20 (5)
21 (6)
19 (6) + C
26
Maximum number of guard zones (with optional sensor) |
11 (14)
11 (14)
11 (14)
19 (22)
19 (22)
20 + CAN
27
The number of protection zones that are turned off from the key fob (with optional sensor) |
5 (8)
5 (8)
5 (8)
11 (14)
11 (14)
11 (14)
28
Shock Sensor |
2 zones
2 zones
2 zones
3 zones
3 zones
3 zones
29
Tilt sensor |
option
option
option
3 zones
3 zones
3 zones
30
Displacement |
option
option
option
3 zones
3 zones
3 zones
31
Motion Sensor |
option
option
option
option
option
option
32
Adjusting the sensitivity of sensors |
keychain
keychain
keychain
keychain
keychain
keychain
33
Automatic adjustment of sensitivity of sensors |
is
is
is
is
is
is
34
Sensor diagnostics during arming |
is
is
is
is
is
is
35
Sensor diagnostics in armed mode |
is
is
is
is
is
is
36
Sensor diagnostics when the system is disarmed |
is
is
is
is
is
is
37
Microphone for listening to the cabin on the phone |
option
option
option
is
is
38
Number of outputs (of which are universal) + CAN |
8 (5)
8 (5)
8 (5)
11 (4)
16 (9)
16 (9) + C
39
Ability to connect the service Magnum Connect |
is
is
is
40
Built-in code immobilizer |
is
is
is
is
is
41
AntiHiJack (number of activation options) |
3
3
3
3
3
3
42
Imitation of engine failure |
is
is
is
is
is
is
43
Starting the engine without a special module |
is
is
44
Starting the engine using the "Start" button |
is
is
45
Autostarting engine when the battery is low |
is
is
46
Autostarting engine when the temperature drops |
is
is
47
Independent engine control inputs |
1
1
2
3
3 + CAN
48
Auto engine start error diagnosis |
is
is
49
Simultaneous blocking of the engine N/Z and N/P relay |
is
is
is
is
is
is
50
Auxiliary Input "Glow Plugs" |
is
is
51
Additional output "Brake" |
is
is
52
Additional exit "Door" |
is
is
is
53
Additional output "Key" |
is
is
54
Additional output "Security" |
is
is
is
is
is
is
55
Delayed arming of the system |
is
is
is
is
is
56
Comfort Function |
is
is
is
is
is
is
57
Light Track function |
is
is
is
is
is
is
58
Programmable output polarity "Dimensions" |
is
is
is
is
is
is
59
Redefinition of power and low-current outputs |
is
is
is
is
is
is
60
Automatic control of TS. when on/off ignition |
is
is
is
is
is
is
61
Automatic control of TS. when on/off parking |
is
is
is
is
is
62
Automatic closing Z.3. from displacement sensor |
is
is
is
63
Turbo timer with manual and automatic start |
is
is
is
is
is
64
Remote trunk release |
is
is
is
is
is
is
65
Two-stage opening of C.3. |
is
is
is
is
is
66
Two-pulse opening Z.3. |
is
is
is
is
is
67
Embedded Relays Z.3. |
is
68
Protection of low-current outlets fuses |
is
is
is
is
is
is
69
Output protection "Light" self-height. fuses |
is
is
is
70
Protection of the Siren output against overloads and KZ. |
is
is
is
71
Automatic electric heating of the GSM module |
is
is
is
72
Automatic electric heating of the SIM holder |
is
is
is
73
Built-in backup battery |
is
is
is
74
Voltage control of a standard car battery |
is
is
is
is
is
is
75
Average current consumption in protection mode, mA |
17
17
17
18
18
20
Magnum GSM car alarms
Summing up the comparative review of the Magnum car alarm functions with GSM of the eighth series:
Bestseller Sales-Magnum MH-820 from the middle of March 2012, is discontinued, it is now replaced by two car alarms:
- Car alarm Magnum MH-822 (low-current control of central locks) for cars with built-in central locking. In essence, the same Magnum MH-820.
- Car alarm Magnum MH-825 (built-in power control central locks) for cars without built-in central locking for easy installation thereof. Analogue bundles-Magnum MH-820/MH-822 + built-in relay.
In the Magnum Elite MH-860 car alarm, a tilt/movement sensor is already integrated, as well as a car alarm system for those who want to be able to connect the G700 GPS module and get more accurate vehicle position coordinates (and additional compatibility with the Magnum Connect system). Also important moment-built-in backup power source (battery). In this car alarm there is an input for connecting a microphone (the ability to listen to the car). And pleasant additions to the Magnum Elite MH-860 will be-additional protection of the outputs and built-in automatic heating of the GSM module and SIM holder. Because of this, the system consumption in the protection mode is slightly (by 1 mA), which, in principle, does not particularly affect the discharge of the car battery.
For those who need additional (to the existing Magnum Elite MH-860), such useful functions as autostart and remote engine start over the phone should pay attention to the top models of car alarm systems-Magnum Elite MH-880 and Magnum Elite MH-880 CAN. The main difference between them is the fact that the latter (MH-880CAN) has an integrated CAN bus adapter of the famous brand TEC Electronics, which produces certified CAN bus adapters. In addition, the design of the keyfobs in the 880th series significantly wins over the entire line of car alarm Magnum.
Otherwise, Magnum GSM car alarms, as the model line grows, do not differ significantly: the design of the key fobs, the number of additional outputs/inputs, possible interlocks, etc. Nevertheless, the Magnum GSM car alarm system is by far the best car security complex on the market with GSM/GPS modules and at the same time absolutely confidently surpasses competitors, both in the technical level and in the price one! Signal Magnum buy in Kharkov, Kiev, Odessa with delivery in Ukraine can be on 130.com.ua.
Materials on the topic
Car alarm Sheriff ZX-750PROBuy4427 ₴ -
Car alarm Sheriff ZX-1095PROBuy5075 ₴ 4156 ₴ -
Car alarm Cyclone X-1000Buy2899 ₴ 2192 ₴ -
Car alarm Cyclone X-470DBuy2849 ₴ 2536 ₴
