New model line GSM car alarm Magnum — MH-820, MH-830, MH-840, MH-840CAN, MH-860, MH-880, MH-880CAN
GSM Evolution! This is the most exact name for the historical event in the area of GSM car alarms sphere. You may not hesitate to declare that finally the event that all car owners anticipated occurred. Now with absolute certainty we can say that there are almost perfect GSM alarm systems! The smallest details and requirements are being accounted. And this is primarily due to the fact that there is an engineering principle "from bottom up": ordinary workers, salespeople and installers are directly involved into the engineering of modern security functions, equipment, assemblage design.
As of today the market of GSM automobile security alarms is really full of suggestions, and it seems of no reason to invent something new. However, the manufacturer attempted to confute this during the development of the eighth series of Magnum alarms.
At the 19-th Kiev International Motor Show SIA’2011, which was held on May 25–29 at the International Exhibition Center (Brovarskoy Prospect, 15), the company "MSS" presented Magnum systems eighth series — Magnum MH-820, Magnum Elite MH-840, Magnum Elite MH-840CAN and Magnum Elite MH-880. Also, soon you can buy Magnum MH-830, Magnum Elite MH-860, Magnum Elite MH-880CAN. By the results of SIA'2011, MCC was awarded a diploma.
GSM car alarm systems analogues available up to now do not allow the installers to choose the type of a security complex building. This is due to the fact that all signal areas, additional channels, ways to respond to events are strictly programmed by developers. Magnum GSM car alarm systems provide the user with a certain set of fully configurable inputs (autonomous security zones) and multiple outputs (additional channels). This means that any input and output can be programmed individually for each client by adjusting such parameters:
- signal zone activation time;
- pause between the additional channels on/off;
- additional channels mask;
- inversion capability.
In addition, the possibility of joining the remote engine start block is worth a separate note (the block is optional and can be purchased separately). Its application is really surprising. For example, in a situation when you leave for a long business trip and you leave the car at the airport parking lot. If you have an on-board Magnum GSM system with Magnum remote engine start block installed at your car, you will receive an automatic SMS message about the battery in the car empty when the voltage drops below 10,5 V, and you can immediately give an order to the system for charging (the engine start for a certain time). And it saves you from the hassle, bustles, wasting time and money because of the battery ran down, when you find this out upon arrival. With such a possibility even an open parking in winter will bring no inconvenience — you can “contact” your car, give the command, get to the parking lot and sit in the car already heated, or in the car already cooled when in summer heat.
It is known that the “weak point” of some GSM devices is network coverage and power supply. For a Magnum system 12 V voltage is not important. In this case, the reserve battery will be switched on. It is constantly charged with a battery charger. And you get a message that there is no voltage or voltage drop at the vehicle network system. Moreover, a new GSM channel control module from Magnum allows monitoring the connection with the signal system in the car. Such a communication control presupposes control messages periodic sending (period specified). The operational management of this function via SMS commands (to disable, enable, set the sending interval) is possible. This means that actually the absolute control of the car integrity is performed.
Features of GSM-car alarm
The operation peculiarities were taken into consideration by the system developers. As a result, the standards for resistance to vibration, high and low temperatures, sudden changes in humidity are strictly met.
The existing expensive GPS systems allow you to track the location of the vehicle within several meters. However, today the price of most of them, as well as the cost of a monthly connection fee is more than just high. In this case a vehicle GSM tracking service is an excellent alternative To this date GSM coverage is effective at actually 100% of the territory, and the possibility of GSM tracking is included into a standard set of additional services of the most of operators. You only need to send an SMS with the request, and you get the coordinates of the location of your car. In fact, if you are interested in the control accurate up to several meters, you can pick up an additional Magnum GPS module, regardless of the operator.
The introduced eighth series of car alarm systems includes Magnum MH-820 and Elite MH-880, Magnum Elite MH-840 and Magnum Elite MH-840CAN. Magnum MH-820 and Elite MH-880 systems work as a standalone unit of protection, and Magnum Elite MH-840 works in conjunction with the standard or pre-installed car alarms. Also, the system can enter into a newly created security complex. Magnum Elite MH-840CAN can be installed in the most modern and high-priced car with a sophisticated electronic system (CAN network) and with the in-service means of the doors opening/closing doors control.
A pre-paid service has a weak point — the balance on the account. And MSS engineers MSS did not leave this unattended. The automatic control of the critical balance of the system card is an innovation of the Magnum GSM car alarms eighth series!
Car protection with the usage of Magnum eighth series systems surprises with the first-class quality and high level. The presented systems have a built-in acoustic impact sensor, replacement sensor and level sensor, a microwave motion sensor, and a microphone for the car audio interception. Now it is impossible to take away your car on evacuator or to remove the wheels without your notice. You will be aware of everything that happens inside and outside the car.
Each system of Magnum latest series is brilliant in its simplicity. The system has a very precise and elaborate design, which allowed a reasonable correlating of the functional filling and the issue of pricing (with no savings in the necessary functions). As a result, there is an offer of the Ukrainian manufacturer of security systems with top features and exceptional quality of building on Samsung Korean line at the democratic “popular” price. And the fact that the system is today officially sold successfully in Russia and Belarus says about the export-beneficial properties of the product abroad. Moreover, in contrast to the imported GSM car alarm systems, all IMEI codes of Magnum GSM alarm systems are included into the database of UCRF (the Ukrainian State Centre of Radio Frequencies) and this ensures that the impending shutdown of grey IMEI will not touch these.
Thus, we should note that it is difficult to confine ourselves to a short list of advantages and benefits of Magnum eighth series car alarms of 2011 line. It is much better to install the system into your car and enjoy with being sure in your car safety and your security quality anywhere in the world. Buy GSM Signaling can be delivered to Kiev, Odessa, Kharkov and throughout Ukraine on 130.com.ua.
Materials on the topic
Car alarm Sheriff ZX-750PROBuy4427 ₴ -
Car alarm Sheriff ZX-1095PROBuy5075 ₴ 4156 ₴ -
Car alarm Cyclone X-1000Buy2899 ₴ 2609 ₴ -
Car alarm Cyclone X-470DBuy2849 ₴ 2536 ₴
