Best GPS Trackers for the car
Vehicle protection is the task of each driver. However, this duty quickly turns into a problem when intruders are activated and machines steal more and more often. It is possible to build an effective security system only with the introduction of a complex of anti-theft devices. One of them is the GPS tracker.
GPS Tracker for Auto - A device that receives a GPS signal with real-time data transfer to your gadget or computer. Yes, you will always know where your car is. And even if your car is stolen, you will be able to quickly locate it and quickly find the intruders.
GPS tracker for car
What features should be present in such devices
The main task of such products is to provide you with information about the location of the car. It is solved using the following functions:
  • Get GPS coordinates. If you want to get the perfect values, then we recommend looking at the models with the presence of GLONASS and GPS.
  • The GSM and GPRS module allow you to receive real-time data.
  • Dimensions: The smaller they are, the better. You can safely hide the device so that intruders can not deactivate the system.
  • Ability to work offline: you can refuse to connect to the onboard network, which greatly expands the functionality and capabilities of the tracker.
  • Interval work. The system then independently communicates over a specified period of time, which is determined in the settings.
Additionally, sensors can be installed. They improve the car's security features. So, at the beginning of the car's movement, you will immediately get a notification and can react more quickly to possible actions of intruders.
Examples of good lighthouses
Today, many manufacturers offer us tracker models. Everyone tries to offer the best functional. The devices with the possibility of autonomous operation have become the most popular.
X-Keeper Invis DUOS — compact GPS tracker: only 70x50x22 mm. The design is not equipped with a moisture-proof body, therefore it is possible to install it only inside the cabin. But there is GLONASS, a microphone for listening and two SIM cards. Transport information is provided on the owner's phone and the official application.
Among the shortcomings we will single out the absence of the motion sensor.
X-Keeper Invis DUOS
StarLine M17 — more advanced model. Due to the sealed housing, it can be used in dusty environments with high humidity. Among the distinctive features is the presence of an accelerometer. As in the previous model, there is GLONASS, a microphone and the ability to receive information through an official application.
StarLine M17
How to set up a GPS tracker
Once we understand what we want to get from the GPS tracker, you need to set it up correctly. Manufacturers are trying to provide detailed information about the product, and most importantly - understandable. Therefore, there is no point in discussing this question in detail, we will discuss only the main points:
  • Set the interval mode to make the device remain invisible. Thus, an attacker will not be able to detect the system's operation and deactivate it.
  • Set the accelerometer to motion. Yes, you can literally get a notification lightly if the car starts moving.
  • Make a GPRS location, and use the official application on your phone. It will be easier for you to monitor the operation of the device and, if necessary, make changes.
We recommend that you select models with the ability to operate autonomously. After all, it will be easier for you to install the tracker.
Where to install the GPS beacon?
There is an important rule here - only the owner should know about the location of the tracker. We recommend that you include your imagination and consider this issue yourself, based on the features of your salon.
You can use the examples of placing the lighthouse:
  • If you have a waterproof model, you can hide it in the engine compartment.
  • Under the lining of the cabin.
  • In the luggage compartment, but try, so it was not the most obvious corner.
  • Inside any designs in the cabin.
If your GPS-tracker is equipped with a microphone, we recommend selecting a suitable place in the cabin.
Buy GPS-trackers in Kiev, Kharkov, Odessa can be at 130.com.ua with delivery to Ukraine.
GPS trackers: Best Sellers
