LED lamps for cars: what you need to know
LED lamps have gained their popularity among car enthusiasts due to their reliability, bright light, economical consumption. There are no doubts that these are practical constructions, the only question remains in choosing the right model.
First, decide your goals. For example, you might just want to improve the light or reduce battery power consumption. There are many options and they all boil down to the advantages of LED lamps:
- More light on 1 W: better performance.
- Even with prolonged work, they do not heat up. By the way, in some cars from the strong heating even plastic burst. So this is the advantage of LED models.
- Bright lighting is another way to improve the design of the car.
- The quality of the lighting is improved, the visibility of the lights increases.
- Longer service life and better resistance to damage.
As you can see, LED lamps are powerful designs with the maximum range of features.
Dipped Beams
In most cases, H7 basepieces are used. Please note that the LED itself should be at the top. For passing beam requires the following parameters:
- Power must be 12 W.
- Light flux from 1000 lm: it is recommended not to use the minimum value, but to choose a model with a large parameter.
- The presence of a cooling radiator.
There are several reasons why a device might not work. For example, the size design or the optical system may not fit the reflector. The choice depends on your particular car.
Low and high beam lamps
LEDs H4 can be used for low and high beams. It is recommended to choose a compact device with a minimum size. Focus on these characteristics:
- Brightness from 1500 Lm.
- Power-from 20 W.
- A radiator with a cooling system is recommended.
If on the package or in the characteristics of the LED indicates one parameter of brightness, it applies to two sources.
High Beam Lamps
Standard base-H1. When choosing, be guided by the minimum power rating, which should be from 20 watts. Brightness-from 1500 Lm. If in other cases the presence of a cooling radiator is only a recommendation, then it is obligatory here.
The main selection criterion is the size of the headlights and features of your car.
LED lamps have real beneficial differences from other designs. Due to what-it is the most popular light source for cars, which is preferred by car owners.
Buy LED car lamps can be delivered to Kiev, Odessa, Kharkov and throughout Ukraine on 130.com .ua.
Materials on the topic
