How to choose LED lights
The LED headlights that have become particularly popular lately are a set of LED diodes. Their advantageous advantages are low power consumption, long service life, increased resistance to moisture and impact. Of course, with its direct task-lighting the road-LED lights do much better. Moreover, the luminous flux does not strain the eyes and does not blind the oncoming drivers.
As you can see, these devices have some advantages, you just need not get lost in a wide range and make the right choice.
Main characteristics of LED headlamps
Almost all models require 12V. But since the diodes react badly to voltage surges, stabilizers need to be connected. All the necessary information is on the base:
- marking;
- working power;
- brightness.
Keep in mind that frontal and brake lights are available without sockets. For such designs, it is recommended to buy two-contact optics, which guarantees compliance with the standards of quality lighting.
Key features of the LED headlamp: power and brightness.
Recommendations for choosing LED-lights
We have prepared for you 6 useful tips to help you choose the most suitable model:
1. The design should be suitable for the method of attachment and connection to the chain for your specific transport. Some headlights and cars may not be compatible at all, so consult an expert before buying.
2. Always study the information on the base. For example, there is one model of the headlamp, but due to different manufacturers, this data may differ. H1-high beam, H7-frontal lamps, H8 and H11-fog. LED bulbs can be bought in Kiev, Odessa, Kharkov with delivery in Ukraine to 130.com.ua.
3. Pay attention that the voltage does not differ from the standard 12V.
4. The standard power of one diode is 5 or 10 watts. The total figure depends on the number of diodes and can even be higher than 500 W.
5. Do not choose models with a luminous flux brightness of less than 1000 lumens.
6. The design of the LED headlight must be built cooling radiator.
Materials on the topic
