Winches for SUVs, ATVs, car towing vehicles
Automobile winch is necessary for every motorist. Difficult road conditions-snow, deep rut, sand, gravel, or impassable dirt-can trap you in places where you can’t expect quick help. Of course, it’s not every day that your car encounters such difficulties, but it happens from time to time. To overcome the off-road used car winches. Initially, the winches were created as lifts , but thanks to technical progress, their capabilities have greatly expanded.
The world leader in the production of automobile winches, the T-MAX company, produces both manual and electric winches for various purposes, structures and capacities. Electric winches T-MAX are designed to operate from the on-board network of a car with a voltage of 12 volts and using a regular car battery. The versatility and versatility of modern electric winches require their proper selection. First of all, it is necessary to calculate the tractive effort of the winch that suits you, according to the formula:
T=M x K, where:
T-the necessary tractive effort of the winch (kg);
M is the mass of the “stretchable” car (kg);
K is the safety factor of the winch's effective operation.
Depending on the conditions of use of the winch, the value of the coefficient K can be:
Winch Application Conditions
| K |
1.5 |
| Pulling a “foreign” stuck car (the calculation takes into account the mass of the car being pulled out) | 2.0 |
| Extreme car tourism and competition | 2.5 |
It is clear that the more powerful the winch, the more successfully it will cope with the task. When choosing a car winch for an SUV or other car, consider the following. The power of the winch drive must match the capabilities of the electrical system of your car. This is especially true of the battery installed on it. If you plan to install the winch permanently, then it should be combined as much as possible with the design of your car. As a rule, the winch is installed on the front (rear) bumper of the car, “kengurin” or in the cargo compartment of the pickup truck. In any case, it is necessary to secure the winch on the supporting elements of the car. A removable installation option is possible when the winch is in the trunk and, if necessary, mounted on a special console bracket, which, together with the installation platform, is attached to the supporting elements of the car. Having decided on the conditions for using a car winch and comparing the characteristics of models, you will be able to independently make the best choice for your car.
Constantly improving the base models, the company T-MAX creates new series of winches. Winches for SUVs or other cars are represented by four series. All of them are electrically operated and have proven themselves in extreme conditions.
The T-Max EW Improved series consists of five basic models with remote wire control. The tractive effort of the winches of this series ranges from 2950 to 5450 kg. The models are equipped with a 5.5 hp sequential excitation electric motor, a 3-step compact gearbox with an automatic brake, a steel cable with electroplated coating.
The T-Max EW OUTBACK series is based on the T-Max EW Improved models and features an improved system for controlling and controlling the winches over the radio channel up to 30 meters, as well as higher performance: engine power from 5.5 to 6.0 horsepower forces and traction-up to 6800 kg.
T-Max EWI OUTBACK Waterproof Series. The system of regulation and control of the winches of this series is waterproof, which allows them to be used to overcome water obstacles and swamps. Such winches are an integral part of equipment for off-road vehicles. The mechanism can be controlled both by a radio channel with a radius of 30 m, and a remote control on a cable 3.7 m long. The power of the electric motor of the models is 6.6 horsepower, the tractive effort is 4530 and 5440 kg.
The T-Max PEW Performance series features models with a tractive force of 4080 to 4305 kg and 5.5 and 6.6 horsepower electric motors. They are equipped with a steel or synthetic Kevlar cable and an improved blue breeze-a hole that serves to pass and reduce the chafing of the cable. Kevlar cable is able to stay on the water and not to sink, which is important. The regulation system for models of this series is with enhanced protection against moisture and dirt, control is via radio or with the help of a remote control via cable.
Recently, electric winches for ATVs are popular, and they are successfully used for
Professional car towing winches: a car hydraulic winch CHW 12000 and a series of T-Max CEW electric winches. Thanks to the complete tightness of the hydraulic motor and hydraulic lines, the CHW 12000 winch can reliably operate completely submerged in water. An important characteristic of a hydraulic motor is its resistance to overloads at which it stops and does not fail. A big plus of this model is hydraulic damping, which in the event of a collision or impact on a fixed obstacle prevents damage to the vehicle or the cargo being carried. The winch is powered by the power steering system of the main vehicle. The absence of electrics in the drive has a positive effect on the reliability of the T-Max CHW 12000 hydraulics winch. The T-Max CEW series models are equipped with a traction force from 4532 to 6800 kg, an electric motor with a power of 6 hp and a multi-stage planetary gearbox. They are equipped with remote cable (10 m) or radio remote control (30 m). Professional electric winches operate from the on-board network of a tow truck with a voltage of 12 or 24 volts. At 130.com.ua you can buy a winch in Kharkov, Odessa, Kiev with delivery in Ukraine.
Manual winches may be the best option for owners of simple cars. The main advantages of hand winches are: simple design and operation, autonomy, high reliability, small size and weight, reasonable price. When choosing a model, you must be guided by the fact that the pulling force of the mechanism must be no less than the weight of the car being pulled out. Using the table, you can easily choose the most suitable model.
| HW-800 | HW-1600 | HW-3200 | ||
| Estimated hook load (kg) | 800 | 1600 | 3200 | |
| Maximum hook load (kg) | 1200 | 2400 | 4000 | |
| Nominal load on the lever * (kg) | 34.75 | 44.65 | 44.65 | |
| Cable movement per cycle (mm) | 52 | 56 | 28 | |
| Recommended cable diameter ** (mm) | 8.3 | 11.0 | 16.0 | |
| Winch weight without rope (kg) | 6.4 | 12.0 | 23.0 | |
| Overall dimensions of the winch (without a lever) | Length (mm) | 426 | 545 | 660 |
| Width (mm) | 64 | 97 | 116 | |
| Height (mm) | 238 | 284 | 325 | |
| The nominal length of the lever (mm) | 80 | 80-120 | 80-120 | |
* With the standard length of the manual winch lever. Increasing the lever tube in 1 meter, you will reduce the force applied 10 times.
** This is the minimum diameter of the working cable.
In difficult situations, use a more powerful model, applying a factor of 1.5 to the indicator. In the case of work "at the limit", the winch can be given all possible assistance (to lay branches under the wheels, slightly spin the wheels of the car while the engine is running).
Make your choice of T-MAX winch on 130.com.ua, based on the conditions of its use and the type of your car! She will become a universal helper-both in a difficult situation on the road and during active recreation.
Related Content:
