Criteria for choosing car mats
Car floor mats are an important barrier that protects the interior of a car from dust and dirt that penetrate inside a shoe. They are an effective means of ensuring cleanliness in the car.
These accessories come in many forms, may differ in technology and material, thickness, shape, size and other characteristics. If you plan to buy floor mats in a car, it is important to know the main selection criteria, we will talk about this in more detail in this article.
What should be the right car mat?
First, keep in mind that these accessories are not only for installation in the car, but also for the luggage compartment. Therefore, when choosing, carefully look at the purpose of the rugs, their size and shape depend on this. This is always indicated by the manufacturer.
Secondly, all salon mats should be made of safe materials. In addition, the material must fit snugly to the floor, not swell and not interfere with the driver, providing full contact with the pedals.
Also note that the mat should not slip or cling to your feet. Equally important, it should be made of a material that is easy to clean and washable.
As you can see, a lot depends on the material, so you should consider this option in more detail.
Mat selection based on the material of manufacture
It is with the selection of material that the choice of car floor mat for the interior should begin. These products are usually made of textiles, polyurethane and rubber. Consider the features of different types of car floor mats.
Textiles
Textile mats with a special water-repellent layer are considered the most practical; they are ideal for placement in the interior of any modern car, you can easily choose a model that fits perfectly into the interior design.
They can vary in thickness and number of layers. As for the thickness, it can be from 4 to 22 mm, here everyone can choose the option that is more like it, but thicker models are more durable. The layers of the mat can be from 1 to 3. The most popular and practical are two-layer models with a thickness of 7 to 14 mm. For example, you can choose two-layer mats made of textiles with an additional layer of rubber on top. They are protected from moisture and will last a long time.
Polyurethane
The advantage of polyurethane rugs is that they have a more affordable price. In addition, thanks to the presence of standard sides, they fit more tightly and reliably protect the entire floor surface. Such models often have a diamond-shaped structure, which significantly increases the degree of moisture absorption from shoes. In particular, such a mat can absorb up to 5 ml of water in each section, providing additional protection against the penetration of snow and drive into the car interior.
Among the advantages of these rugs, one can also note a rather simple care - just shake the product and all the water collected in it will pour out. This type of floor mats is practical, as it guarantees reliable protection of the bottom of the car and trunk from dampness and moisture drops.
Rubber
This type of car floor mats is considered the simplest and at the same time the most practical. Such models are also sometimes called anti-slip, since the rubber sheet of such rugs has special spikes that prevent even wet shoes from slipping.
Among the features of rugs of this type, one can also distinguish their shape, which has high sides and separate sections into which the entire surface is divided. As a rule, such models have a rather large thickness - about 20 mm. Due to this, they are resistant to mechanical abrasion, which increases their service life.
What other auto parameters Do you want to watch the floor mats when choosing them?
In addition to the choice of material, when choosing rugs, you should pay attention to a number of other important parameters. In particular, there are three additional criteria that are important to consider before making a purchase:
  • Secure fixation on the floor. For rubber and textile floor mats, look to see if there is a special locking system that looks like a small hole for the nozzle in the passenger compartment. In addition, the driver's mat must be able to securely mount, it should not hang and move.
  • Exactly matching the size of the mat to the dimensions of the interior. In order for the canvas to provide a good level of tightness, it is recommended to buy not universal models of salon mats, but model ones. In this case, you can be 100% sure that the dimensions are ideal for your particular car model.
  • Lack of pungent chemical odors. Good rugs should not have an unpleasant artificial smell, as they are made of high-quality, non-toxic and environmentally friendly materials.
You can buy car mats in our online store 130.com.ua. Our catalog presents a wide selection of model and universal models. If necessary, managers will help you choose the best option.
Related Content
