What are vacuum cleaners for cars and how to choose the best model
Every car owner monitors the cleanliness of his car. It is easy if passengers appear rarely. But what if the frequent rear-seat guests are small children and your four-legged friend? Probably, the car wash has to call in often. Of course, the cabin is always clean, but how much time this procedure takes, and most importantly, money.
In such situations, portable vacuum cleaners become an assistant, with the help of which you can get rid of dust and dirt in two ways.
Why a vacuum cleaner and not a regular one?
Why should I buy a car vacuum cleaner, if you can use the usual one, some car owners think and are disappointed with the first procedure. Imagine how much effort you need to pull out your home vacuum cleaner on the street, and then also remove a small salon with a huge brush. And not to mention the comfort, the effectiveness of such cleaning is very low.
Advantages of car vacuum cleaners:
- Size: you can remove even the most distant and compact parts of the car. So, garbage will not be in the entire cabin, and not only in visible places.
- Type of food. If you use a conventional device, you immediately need to think over where to find the outlet. Car models work either from the cigarette lighter or have a built-in battery.
- Mobility. You can store the vacuum cleaner in the trunk and use at least in the parking office. A funny picture will be, if you clean the car in the same parking lot, but with a regular vacuum cleaner.
- Lightness. Models weigh up to 1.5 kg., Very rarely-more, and that is due to the large set of functions.
Kinds of car vacuum cleaners
You can use a dust collector for dry and wet cleaning. But this factor must be foreseen in advance: some models are designed for only one type of cleaning.
Car vacuum cleaners for dry cleaning are inexpensive at the expense of less functionality. In practice, they only clean the dry garbage. Ideal for daily cleaning salon.
Washing models are helpers when it’s snowing or raining outside. Such designs remove dirt and traces of puddles. And of course, copes with wet spots on the seats. Additionally, they can be equipped with filters that clean the air from dust. Differ in higher price and greater weight.
Charging Methods
When choosing a car vacuum cleaner, also consider charging method: for some, this factor can be decisive. Conventionally, all models can be divided into the following types:
- with built-in battery;
- powered by mains or cigarette lighter;
- universal: they combine type 1 and 2.
So consider each option in more detail.
The models with a built-in battery are the most functional, since your cleaning does not depend on the length of the wire: you can reach even the most remote places. But there are drawbacks, because the design is heavier and more expensive. Keep in mind that the battery may be discharged. On average, its charge lasts for 30 minutes, but it all depends on the model.
Car vacuum cleaners, working from the mains or cigarette lighter, provide longer operation. Then pay attention to the length of the wire, because it determines how effective your cleaning will be. Consider that if the model works from the cigarette lighter, then it reduces the battery charge. So do not stay too long: stay within 30-40 minutes.
The best option is the third. If the battery of the vacuum cleaner is empty, you can connect it to the cigarette lighter and continue cleaning.
Power
One of the main selection criteria is instrument power. If you choose the wrong model, you will not be able to clean the interior as qualitatively as possible.
Here the range offers us a wide choice: the power varies from 40-180 watts. The higher this figure, the better the vacuum cleaner works. But you don’t need to choose the model with the highest setting.
So, for easy cleaning a couple of times a week, 75-80 watts are enough. If you have a truck and you need to clean it regularly, then look at more powerful units.
Basic and optional equipment
Inside the car can be different surfaces and textures, especially if you have a design registration. Therefore, many manufacturers of vacuum cleaners are trying to make their products universal, suitable for cleaning different surfaces. But here consider: the wider the equipment, the higher the price.
Include some tricks: buy a car vacuum cleaner as standard, and only if necessary buy separately the necessary nozzles.
Basic set:
- A large, standard brush for carpet surfaces.
- Brush nozzle: for soft tissue.
- Slit tube: for cleaning remote areas.
Extra set:
- Turbo brush: for cleaning hair and hair.
- Brush polishing: for delicate surfaces.
- Round: for drape and velor surfaces.
So, now in your hands a comprehensive instruction: how to buy a car vacuum cleaner. Use the above recommendations and choose the best option for yourself. You can buy a car vacuum cleaner in Kharkov, Odessa, Kiev with delivery in Ukraine at 130.com.ua.
Materials on the topic
Car vacuum cleaners: Best Sellers
