Heated seats: what happens and what to choose
Modern luxury cars are often all equipped with heated seats. For owners of earlier models, the possibility of additional installation of such structures is provided.
There are three types of heating:
- Cape is an external heating system, it is easy to install. You can shoot it if necessary. Not designed for washing and often installed on the front seats.
- Cover - you do not need to install to use the heated cover, just put it on the car seat and connect it to cigarette lighter. Such heating can not only warm in winter, they also perfectly complement the design of the car.
- Built-in is a more reliable option, but at the same time more difficult to install. Special flexible panels are inserted into the seat and connected to the vehicle electrical system. Many models are equipped with electrical protection. To remove such a structure, if necessary, will be much more difficult.
All three options are high quality and reliable, differing only in the complexity of installation.
Advantages of heated seats
Probably everyone is familiar with the situation when in a very cold cabin you have to wait until the engine warms up, the air in the cabin and only then the seats. In this connection, the installation of heated seats has several advantages:
- Comfort-it is difficult to meet a person who would enjoy the pleasure of waiting for his car to warm up. It is much more convenient to sit down and get a warm place for a further trip in a minute.
- Savings. There are already a lot of additional heaters for cars, but they are more expensive and less efficient: heated seats provide heat for your place, thereby heating up more quickly due to local work.
- Health: if you are always warm, the risk of catching a cold will be kept to a minimum. But here the design features do not end there, and it can be used to prevent sprains, sciatica or arthritis.
Buy heated seats – it means to purchase a multifunctional device that will warm you well even in the most severe frost.
How to install built-in heated seats?
Modern designs are simplified to the maximum, so that everyone can cope with the installation process. So, the installation includes the following steps:
- Remove the seat from the mounts: this must be done, because otherwise it will be inconvenient to work, and the quality of such work is significantly reduced.
- Remove or slide (depending on the model of the car and the characteristics of its seats) upholstery and filling.
- According to the instructions, install heating on the back or pillow. There are models designed only for the back or pillow-consider this.
- We recommend that you immediately check the functionality of all nodes in order to fix them immediately in case of any problems.
- Return the contents and upholstery back.
After installation, to prolong the life, do not allow moisture to enter the structure and, if possible, be careful with the wires.
Features heated seats
Heat is not all the conditions of comfort that you can get. Heating systems may have additional features:
- The ability to set a separate temperature for the backrest and cushion is ideal if you want different temperatures in different areas.
- So that, as they say, do not fry in the seat, the models are equipped with an additional timer or temperature control system. So, when a certain value is reached on the thermometer, the device will either turn off or continue to support the mode.
- The ability to adjust the degree of heating with a thermal switch
Heated seats is an opportunity to even sit in the dead frost and go, not wait, until the cabin becomes more or less warm and freeze for a while on the road. Please note that such constructions heat up very quickly, due to which they are more efficient.
You can buy heated seats on the website 130.com.ua in Kiev, Kharkov, Odessa and with delivery in Ukraine. Reasonable prices and a wide range of products will allow everyone to make the perfect choice.
Materials on the topic
Seat warmers: Best Sellers
