How to choose a marine radio and sound
The most important mechanism in the entire system is the head unit. These are special receivers for use in conditions of high humidity, and in appearance they resemble models for cars. Their difference is that they are designed to work in extreme conditions, for example, on an open surface with direct contact of UV radiation.
The display is of high quality: everything is clearly visible even in bright sunshine. During production, the companies adhere to special standards for boats and yachts.
For receivers with a lower level of moisture protection, protective boxes are provided. There are models that are protected only from splashes. The difference is the external protection of connectors, internal mechanisms. For some devices there is a remote control. This improves the comfort of their operation.
Marine Acoustics Features
Marine Acoustics , as well as the radio, should have an appropriate level of protection. Such devices use high-quality diffusers made of moisture-resistant materials, the speaker coils are equipped with additional elements to protect against water.
Speaker nets are made of plastic, completed with rubber bands. In this case, the sound does not differ from the designs for the car. Shows high quality even in open space.
Marine speakers can be designed for installation in the hull of the boat, and ramp. The second option is a closed design with rubberized inserts at the junction points. You can buy marine recorders and media receivers in Kiev, Kharkov, Odessa at 130.com.ua with delivery in Ukraine.
Marine subwoofers, as well as models for cars, make the sound more powerful and better. They are more powerful due to larger magnets and reinforced coils.
Materials on the topic
