How to choose a tourist gas stove?
Recently, tourists are increasingly opting for portable models of gas stoves and stoves for hiking. After all, after spending the whole day in nature, there will be no energy left to collect firewood and light a fire. By the way, such an attribute as a tourist gas stove has long been used by fans of fishing, hunting and outdoor recreation. However, before you buy a gas stove, we advise you to figure out what you should pay attention to when choosing.
Benefits of portable fire sources
First of all, tourist stoves and burners are lightweight and compact. Therefore, they can even fit in a backpack. Most hobs have a wide hob for quick cooking and preheating the kettle.
Considering that fire sources are used mainly in field conditions, they have good stability, high power and efficiency. Models may differ in their appearance, the ability to adjust the flame, protection against spontaneous activation, a bag for transportation.
Types of portable stoves
Camping sources of open fire are divided into two types: stoves and burners.
Camping gas burners
Camping gas burners
The main elements are a mixer and a gas burner head with a stabilizing device. Burners can be of different designs depending on the components they make. In remote controls, fuel is supplied from the tank through a hose that connects to the head. In stationary models, the head is located on the fuel tank itself.
Camping gas stoves
In appearance, they resemble stationary ones. They can have one or more burners, a gas supply hose and a piezoelectric element for auto ignition. The body of such plates is metal, and the burners, depending on the model, can be aluminum or ceramic. The latter are considered safer, withstand low temperatures, have low fuel consumption, but they are also more expensive.
Camping gas stoves
The plates can also be connected to the fuel tank using a hose, or they have a built-in collet tank. There are also combined models that can use both a portable and an internal tank.
In order to buy a portable burner or stove and it brought you maximum benefit, you need to pay attention to such parameters as: fuel consumption, weight, power, hob width, piezo ignition and protective elements.
Fuel consumption
Information on fuel consumption is indicated in the data sheet of the device. This parameter indicates the time at which one liter of water will boil. Accordingly, the lower this indicator, the greater the gas consumption.
Weight
The models differ in their design and the materials used in production. Camping slabs can weigh between 0.8 and 5 kg. For hiking, of course, it is better to choose the lightest option.
Compact gas burner
Power
It is quite simple to calculate the power when choosing a device. One liter of cooking consumes 1 kW. On average, one serving of food for an adult is 0.5-0.7 kg. Thus, a cooker with a capacity of 1-1.5 kW will be enough for two tourists.
Hob width
On a wider surface, you can position larger dishes and cook a large amount of food in one go. This is true for a large family or company.
Piezo ignition
With the help of a piezoelectric element, you can light a fire with one click. This is very convenient as it saves time. However, in conditions of high humidity, it can fail, so it is better to additionally stock up on a lighter and matches.
Protective elements
Protective elements
Some models can be equipped with special devices for protection from precipitation and fire. In any case, they can always be purchased additionally.
In conclusion, I would like to say that choosing a portable stove or burner is not as difficult as it seems. These robust and practical devices help you quickly prepare food anywhere and in all weather conditions.
You can always buy a tourist gas stove in Kiev in the online store 130.com.ua with delivery across Ukraine. We have a large selection of various models of portable burners and stoves at a very attractive price.
Related materials
