How to choose a portable speaker: acoustic test drive
We have prepared a detailed manual for choosing a portable speaker. Understand the power, battery capacity and other parameters that turn a normal sound source into an indispensable companion.
The main advantage of portable acoustics is that with the help of it you can listen to music anywhere. It works on both the built-in battery and the mains. Such devices can be used for home, parties, cottages and recreation. Choose a model is necessary, focusing on further operating conditions.
Portable speaker for home
An acoustic system for home use should be powerful, produce good, clean sound and at the same time have a nice design. Compact size and battery life in this case are less important.
During the selection, the following should be considered::
  • Power: in the range of 5-20 watts. - optimal solution. Too loud sound for home operation is not needed, but at the same time, even at maximum volume, the sound will be clear.
  • The frequency range: 70-21000 Hz. Even for watching a movie or listening to music, the sound quality should not be lower than the average level.
  • Autonomy period: not important, because at any time the column can be connected to the mains.
The presence of Bluetooth will greatly facilitate the connection of acoustics with other devices. Some models can be equipped with a speakerphone: it allows you to receive calls from your phone or tablet.
For trips: summer residence, rest, travel
For such purposes, light and compact models with high power and long autonomous operation are ideally suited. Main settings:
  • Power: in the range of 5-40 watts. Please note that this parameter should be sufficient for the music to be able to shout over the surrounding noise.
  • Frequency range: 80-2000 Hz. In this case, the sound quality is not paramount, so average values will suffice.
  • Battery life: 5-15 hours. It all depends on your wishes.
Among the additional features can be the ability to wirelessly connect to a smartphone or tablet. Some models provide the option of noise reduction, due to which the sound even during bad weather sounds clear. There are devices with a special element for attaching to clothing or a backpack.
For a grand party
For this purpose, it is important to select powerful speakers, which even at maximum volume can produce a clear sound. Well, if it is reinforced with a unique design. Basic options for selection:
  • Power: up to 250 watts, but the higher, the better. After all, for the party, music is of paramount importance.
  • Frequency range: up to 22000 Hz. Believe me, everyone will be happy if the sound is clean and quality.
  • The battery life is important in case it is an open-air party. In this case, the parameter should be from 8 to 24 hours.
Among the additional options may be an equalizer for adjusting additional effects, wireless connection or the use of multiple columns at the same time.
Buy portable speakers can be delivered to Kiev, Odessa, Kharkov and all over Ukraine at 130.com.ua.
Recommended
