How to choose a good mini-wash for a car. 10 parameters to pay attention to
Maintaining cleanliness in a car is a complicated and less than pleasant business. But we still visit the car wash and try to make the car always clean outside and inside. In order to cope with this process independently, we use auxiliary devices.
A bucket and a rag do not inspire a chance of success, but the mini-bowl does its job well: it directs the flow of water under high pressure to the right place. Buying such a design is not only a reasonable solution, but also profitable. After all, you save on car wash services, and an extended range of models allows you to choose a mini-bowl that is functional and economical.
So, in order to properly choose a device, you need to first determine which parameters to pay attention to.
Types of sinks
All high-pressure devices are operated by an electric motor from a fixed network. Models are single-phase and more powerful. Yes, all mini-washings are aimed at solving one task, but all of them are distinguished by the availability of available functions, quality and design.
Household washers
Often the most affordable models are characterized by a small power parameter. Suitable if you only need to wash the car occasionally. They differ in a small cycle of working time, so it is rational to buy them for personal use, in small and medium business they will be completely ineffective. Household mini-wash should often be turned off, because they can overheat and generally break down.
Often the pump is made of high-quality plastic. The disadvantage of this material is that it is not designed for high temperatures. Advantages of such models:
- low price;
- easy to use;
- light weight.
Semi-professional and professional mini-wash
Such models are much more expensive, but their feature is in long service life. If you plan to carry out the washing procedure often, then the purchase of this type of device will be profitable and justified. Ideal option - for car washes and service stations. If we compare them with household models, then semi-professional and professional have better performance parameters, pressure, power.
Here, better materials are used for the pump. For example, plastic that can withstand high temperatures or silumin.
Industrial washers
Used to clean large machines and aircraft. Of course, here the functional is much wider than in previous models. For example, the main features:
- Work with cold and hot water;
- It is possible to set the required temperature for water independently;
- Built-in manometer;
- The material used for the pump is brass;
- Three-phase power supply in most cases.
Of course, buying such models for home - inefficient and unprofitable.
By the way of water intake, the sinks can also be taken from the tank or from the water supply system.
Where to use mini-wash?
Apparatuses of high pressure have become popular in Ukraine and are most often used for passenger cars, but this is not the end of their application: bicycles, motorcycles, boats, trucks, airplanes. Designed not only for home use, but also for car-care centers, service stations and car washes.
Many mini-launches became popular even in the construction industry. With their help, they wash pipes, concrete mixers and other structures. In agriculture they are used for cleaning stables, pigsties and barns.
Surprisingly, even in the fishing industry, mini-mouses are used. For example, on boats, where after fishing there are a lot of garbage, which is difficult to remove by hand. Such high-pressure devices are also used in food production, in the spheres of public catering.
And of course, the mini-wash is an assistant for every mistress. Such devices will help to clean furniture and any other household items faster and more efficiently.
10 useful tips: what to consider before buying?
So, when choosing the right model, consider these characteristics:
- 1. Productivity - the water supply force depends on it. In household models, this parameter varies between 6-12 liters/minute.
- 2. The maximum pressure is on average 70-150 bar. In principle, for effective cleaning of cars such parameters are more than enough.
- 3. The pump in the electric pump must be made of a durable material. For example, the mechanism of plastic can not guarantee a long service life. It is better to give preference to metal.
- 4. The filter is designed to protect water from dust and debris. It is more practical to use reusable structures.
- 5. The system of water heating - here you can not depend on the domestic water supply. Function is especially useful in winter.
- 6. The Total Stop system is designed to save water. Ensures that one cycle does not last more than 20 minutes.
- 7. Nozzles allow using the mini-bowl universally.
- 8. The size of the hose should be such that you can easily reach any part of your car. Standard - 5-7 m.
- 9. It is envisaged to use detergents to improve the result.
- 10. Outlet water temperature.
These tips will help you choose the right mini-bowl to suit your wishes. As you can see, such designs will become an assistant in everyday life and in production. At 130.com.ua you can buy mini-wash in Kharkov, Odessa, Kiev with delivery to Ukraine.
Related materials:
Mini-washers: Best Sellers
