How to choose an action camera and not suffer
The standard premise of almost all the articles on the choice of action cameras is this: decide for the purpose of acquiring the device and the amount-from this and dance. It seems that the approach is quite reasonable, but in practice it is a direct road to the abyss of suffering.
In fact, to choose the right model, you need to know quite a bit. This is what we will tell you.
Matrix resolution
Depending on the model, action cameras are equipped with a matrix with a resolution from 720p to 4K. According to the manufacturers, such a spread is necessary so that the buyer has a choice. It is assumed that the device with 720r. enough for family shooting, 1080p. suitable for removing the blog, but the owners of multicopter can not do without devices with 4K. In theory, everything seems logical, but in practice something completely different happens.
The larger the matrix, the higher the image detail. And with any choice you will always miss this option, because you always want more. And do not forget about the photos. If the video can be removed with any resolution, then on the screenshot from 720 p. you can only look and be disappointed. But in the photo with a resolution of 4K. you can watch and admire.
Frame rate
The more frames you can record in a second, the better the video will be. For example, films are shot at a frequency of 24 frames per second. For normal video perception, television standards are ideal: 25-30 fps.
The action camera is an extreme sports product, so it can give out big parameters. For example, 60 and even 240 fps. These frequencies will allow you to watch videos in slow motion.
The ability of some models to work with a reduced or adjustable frame rate is useful. an action camera to buy in Kiev, Kharkov, Odessa, and also with delivery in Ukraine, you can on 130.com. ua.
Lens
The lenses of an action camera are wide-angle, because as soon as such devices can accommodate a maximum of objects and give a good depth of field. So, not only nearby objects, but also distant objects get into focus. Note that these devices do not provide autofocus.
But in wide-angle lenses, the image is slightly distorted or, as they used to say today, with the effect of a fish eye. Good cameras can adjust the image, turning it into a flat image.
Interface with Buns
A camera with a screen in any case will be more convenient. But there are cases when it is only superfluous. For example, if you use the helmet version. Then wirelessly connecting to a smartphone is the best solution.
With the help of a gyroscope and a G-sensor, you can save battery and memory space. Useful, but optional features-noise level, optical stabilization.
Battery
It’s important to only consider how long the battery will last, whether it can be quickly replaced if necessary and how long it takes to charge. It is better to read reviews for a specific model.
Accessories
Tripod fasteners, boxes for underwater shooting, remote controls for remote control-all this may need to everyone. Therefore, in advance, think about buying additional accessories. For premium models, they are available in almost all stores, but with a simpler device will have to be a little confused. Sometimes it's better to buy accessories from GoPro than to wait for delivery from Chinese stores.
Mass and Design
Modern models are all light and versatile. From the assortment, only devices for helmet-wearing are distinguished, since they often have minimal windage.
Total
If you rely on quite a small amount, you will have to choose from what is now available to you. But believe, as practice shows, in any case, you want more. We recommend spending time on a good model, but then enjoy the result.
Materials on the topic:
