Choosing daytime running lights-tips
The rules of the road establish that daytime running lights are an indispensable component of a modern car. Unfortunately, these designs are not included in the standard equipment of many cars. Of course, you can use some other analogues instead, but still many drivers are faced with the choice of daytime running lights.
We will understand how to choose the optimal set of lighting and what parameters need to be taken into account.
Specificity of daytime running lights
Daytime running lights improve the visibility of the vehicle in the daytime. They can be combined with other elements of lighting or installed separately. Sometimes they are mistakenly compared with the parking lights, but in fact, the latter are necessary to indicate the size of the car during parking. And they are used in conditions of insufficient visibility. They are also known as “parking lights.”
The same rules of the road establish that instead of DRL you can use fog. Hence the question: why are the first needed, if other structures can easily cope with their functions? Each device has its own task. Therefore, daytime running lights better cope with their purpose.
Under equal conditions, DRLs will be more economical, therefore, they can work continuously for a long time. If you turn on the low beam, the side lights are activated along with it, the dashboard lights, respectively, the fuel consumption also increases.
Legal regulations expose such requirements for daytime running lights:
- glow angle-30 degrees;
- illuminated area-from 40 cm square;
- emission of light with a power in the range of 400-800 Candela;
- installation for all sizes of cars.
DRLs are used only to illuminate the road during the day, so they work according to the principle: the light is visible, but not blinding.
Types of daytime running lights
Depending on how the lighting elements are installed, these types of structures are distinguished:
- with incandescent bulbs: inexpensive, have a weak glow, not economical to use;
- with halogens: energy-consuming, last longer and shine brighter;
- LED: they serve for a long time, they shine brightly, they are energy efficient.
The best option is the LED DRL, although the savings will not appear immediately, but it will be visible with time.
Daytime Running Lights
Once you have decided on the type of DRL, proceed to the assessment and other nuances:
Power glow. Here it is necessary to take into account the origin of the lighting mechanisms. Chinese models with the same power condition can produce 1.5 times less than European models. Example: Chinese-8 watts. and no more than 700 Lm., and European with 8 W-from 1000 Lm. And here it is also important to take into account not the watts and lumen, but the intensity of light in candela.
The voltage depends on the capabilities of the machine battery. The average is 12 watts.
Standard DRLs should be protected from contact with external objects, from dust, water. To do this, use the IP protection class, where the first digit is the level of dust resistance, the second is water resistance.
Installation. The most optimal-insert in the bumper and the use of the bracket. Several fixtures may be available.
Additionally, you can also take into account the color temperature of the lights: the higher it is, the brighter the light. There is also a function to automatically turn on the DRL when the engine is started, protection from improper connection, etc. With these features, you can significantly improve the efficiency of using daytime running lights.
For drivers who frequently use cars, it is recommended to choose models with a sidebar in the bumper and with IP 65-67 protection. If you first meet with such structures, then look at the models on the bracket.
you can buy daytime running lights with delivery to Kiev, Odessa, Kharkov and all over Ukraine for 130.com.ua.
Materials on the topic
Daytime Running Lights: Best Sellers
