Call
Choice and preparation of daytime running lights
A few years ago, DRLs were just a fashion accessory, and basically they were put to give the car a more modern and presentable look. Now buy daytime running lights-it is also to get practical value, since the Ukrainian legislation says that during the daytime from October 1 to May 1, cars that are moving on country roads should have the dipped headlights or running lights on. lights. Despite the fact that the law provides for the use of only standard running lights (it is forbidden to independently refit and install additional lighting devices in the car), it will be very difficult for a police officer to prove to you that the DRLs that are installed on the car are not regular ones. To prove the illegality of the installation of lights will require special expertise, which is a very complex and time-consuming process. Therefore, the police do not want to do this and allow motorists to quietly refit their cars and enjoy a comfortable ride. DRL buy with delivery in Ukraine to Kharkov, Kiev, Odessa, you can on 130.com.ua.
If all of you decided to set yourself a DRL, the question immediately arises: which model to choose and where to install it on the bumper. Daytime running lights are best mounted as widely as possible relative to the body, so as to mark the dimensions of the car.
Rules for installing DRL
Naturally, in the world there are a huge number of makes and models of cars, which differ in the design of the bumper, and, unfortunately, it is not always possible to install the DRL as widely as possible. For some cases, you have to cut the bumper or grille, and not every car owner will agree to that. Therefore, in recent years, many options have been devised for the installation of DRLs.
DRL Installation Methods
The easiest and most popular way is to mount with the help of mounting brackets, which are mounted on the sides of the DRL headlights. In such brackets there are special holes for fixing screws. The mounting brackets have mobility in angle of inclination and departure, so the running lights can be set exactly relative to the bumper.
Another option is to install using the mounting panel. In the free cavity of the bumper, the mounting panel is first fixed, and the headlight itself is fixed to it using the latches.
The advantage of the first two options is ease of installation, and a minus-you need to have free space on the bumper or grille.
If there is no free space on the bumper, you can use DRLs that are glued to the bumper with double-sided tape. Navigation lights of this type have a different shape and size: from the simplest straight to navigation lights, which are made in the form of flames. The main advantage is ease of installation, and a minus is the fragility of the adhesive layer, due to which the lights can fly off over time on the track or during washing.
Universal DRL
If the options above do not fit, there is a more radical way to install by tapping the running lights into the bumper. For the implementation of the inset process, 2 options are used.
The first option is the running lights, which consist of separate LED modules connected together as a garland. In order to install them in the bumper make the required number of holes and in each of them install the modules separately. Thus, on the bumper, you can make different compositions of different shapes and sizes.
The second option is a solid LED headlight, which has a small bend in length in order to repeat the shape of the bumper. To install these lights in the bumper cut out a rectangular hole that fits the size of the headlights.
Basically, for the first and second options, the fixation of DRLs occurs with a sealant, unless other fastening mechanisms are provided in the package. The very sidebar option looks aesthetically pleasing and more attractive than others, but if the mortise DRLs fail, then to replace them you will need to find a model that will be the same or similar in size hole that has already been made in the bumper.
DRL can also be put in place of fog lights. Especially for this, there are round-shaped running lights in various diameters. DRLs, which are installed instead of protivotumanok, will be as wide as possible relative to the car body and will not spoil the exterior. The downside is that, unlike fog lights, the running lights have a cold emission spectrum with a diffuse beam that is ineffective in fog.
DRL instead of fog lights
If you do not want to sacrifice fog for the DRL, there is a more expensive option-a combination of fog lights and running lights. Such products, for example, can be found in the assortment of OSRAM.
The last and most attractive option is the regular DRLs, which are made under a certain brand and model of the car and mounted in regular places. With these lights do not need additional alteration of the bumper or grille, and the original design of the car is perfectly preserved.
Regular DRL
DRL Features
In addition to the installation method, the lights may differ with additional features. For example, bright DRLs can switch from day to night mode. In night mode, the LEDs shine dimmer so as not to blind oncoming drivers. There are also running lights with a turn signal repeater function.
When choosing a DRL, you need to pay attention to the shade of the glow, as there are lights with warm yellowish or cold bluish shades. The best option-is to buy DRLs that match the color of the glow with low beam headlights and dimensions. This will add aesthetics to the car.
Now that the choice is made, you need to think about the connection option. Daytime running lights can be displayed on a separate button and independently make a decision on switching on or off. In this case, you can simply forget to turn them on. A much more convenient way is to connect the DRL to the ignition switch so that they automatically turn on when you turn the key. For this type of connection is best suited lights with the function of the night mode, the light of which will dim after turning on the dipped headlights.
TOP 3 daytime running lights
Best automobile DRL
Looking for a quality and the best daytime running lights? This rating of daytime running lights is made on the basis of such parameters as: high demand with positive feedback from our customers, high-quality manufacturing — absence of factory defects and service calls, and official warranty and post warranty support in Ukraine.
LED daytime running lights OSRAM LEDriving PX-5 (DRL 301)
Features:
  • ★ 5 LEDs
  • ★ Low power consumption
  • ★ Compliant with ECE E4 and ECE R87
DRL Philips LED Daylight 9
Features:
  • ★ Light intensity 400 cd
  • ★ High quality aluminum housing
  • ★ Compatible with the system "Start-Stop"
OSRAM LEDriving LG Daytime Running Light (DRL 102)
Features:
  • ★ High temperature ranges
  • ★ Shockproof and moisture resistant
  • ★ The color flow of light – white and blue
Materials on the topic
Daytime Running Lights: Best Sellers
