How to choose a car radio with a retractable screen
The time of tape recorders and radio is slowly receding into the past. No, of course, such a rarity is still found in the cars of our motorists, but if you keep up with the times, please pay attention to the car radio with a retractable screen.
Why do you need car radios with a retractable screen
Having acquired such a treasure as a car radio, you will not become sad and nervous in the congestion, you can cheer your guests at a picnic or listen to light calm music when you get out on a fishing trip. You will be able to keep your children on the road watching a cartoon, and they will not interfere with driving. If you connect a rear view camera, it will work when you turn on the reverse gear. If you set up mirroring, then you no longer need parking sensors. The parking lot will now be safe, you won't hit anyone, won't hit the curb. Tempting, isn't is it?
Advantages and disadvantages of a car radio with a retractable screen
Like every thing, a car radio has its own strengths and weaknesses. You can weigh all the PROS and CONS and make your right choice when buying. We will try to help this and tell you about the different nuances.
Advantages
1. Small dimensions mean a lot of free space in the salon. If you don't need the screen, you can close it.
2. The slide-out radio has a large display for a clear picture.
3. It is a modern multi-functional media system.
4. Touch control is displayed on the screen of the radio. You can select the desired function right on the go, there is no need to stop.
5. If you have a TV tuner and an antenna, you can enjoy watching satellite TV (both in traffic and in a traffic jam). However, in motion picture quality drops slightly.
6. The display can be divided into two zones: navigator and video. Note that is synchronous.
7. The details of large objects are much clearer, which is also important.
8. The screen works as a standalone navigator. And means there is no need for additional purchase of a separate navigator.
9. Possibility to connect a parking radar. The fear of damaging the car is thus minimized.
Disadvantages
1. The retractable screen is a retractable part that is subject to constant vibration. It is shaking that she is afraid. If and you have to wait for a breakdown, then most likely it is the retractable mechanism that will suffer.
2. Vibration during movement has a detrimental effect and on the connection loop.
3. Cheap models suffer from problems with the sensor matrix. This means it's not worth saving.
4. The retractable screen can interfere with the operation of the air ducts. But does not apply to all car models.
What are the nuances in choosing a radio?
Start saving money for a good radio tape recorder. Do not chase inexpensive models, because it is better to pay once, and do not pay extra regularly for repairs-the result will be much more expensive. Yes, and nerves will go away a fair amount. You should pay attention to what is your front panel. The car radio model should fit perfectly and not be difficult to connect. Look at assignment and convenient location of ports and connectors.
Think about the fixing strength and about the reliability of the retractable mechanics. Screen resolution is an important part of performance. A monitor in 7 inches with a resolution of 800x400 pixels will be a good choice.
The visibility of the screen (better than 120 degrees) should allow you to see the picture clearly and from the driver's seat, and from the passenger seats. It is important to know about the linear power of the car radio, the reproducible frequencies, the automatic anti-shock stabilization function.
Also important is the ability to connect a subwoofer (this is a speaker system that reproduces low-frequency sounds, including infrasound) to the radio. Supported formats of CDs and DVDs and playable files, whether Bluetooth is built-in (this allows you to make phone conversations while driving), whether there is a built-in GPS navigator-all these are also important details. A TV tuner, antenna and remote control will not be superfluous.
A useful function will be the ability to reproduce zone sound (equivalent sound from all sides of the car). The amount of memory and understandable menu in Russian is what will make the convenience, and not vice versa. It is also important to automatically adjust the brightness and contrast of the image based on the degree of lighting in the car interior. If there is LED backlighting, that's great.
Select and buy a car radio with a retractable screen with delivery in Kiev, Kharkov, Odessa and all over Ukraine is available at 130.com.ua.
Related materials:
Car stereos: Best Sellers
