How to choose a car radio in 2020?
All on the market car stereos are distinguished in many ways. And before you buy it is important to determine the order which model is suitable for you and your car.
There are several basic types of radios:
- CD/DVD-players;
- digital recorders and receivers.
It is also worth remembering that they can have one of two standard housing sizes, which must be taken into account when setting:
- 1 DIN - 178h50 mm;
- 2 DIN - 178h100 mm .
What to look for when choosing a car stereo?
- As has been said, we must be sure to know the size and parameters of the existing holes in the car. They are best measured in advance, so you do not have problems.
- Consider on what media will listen to music (flash drive, CD, memory card, etc.).
- Almost all current models have a connector for USB-cable connection, it is an important feature, if it is not, it reduces the functionality of the model.
- Experts recommend choosing the radio tuner with a sensitivity of 1 mV.
- An important parameter is the number of channels to connect the speakers. The more radio channels is, the more the speaker/sound sources can be connected thereto. Here in the selection must take into account the actual number of used acoustic devices inside the car.
- The presence of an equalizer allows you to adjust the sound, the more bars, the greater the possibility of adjustment.
- If you are going to connect to the head unit external amplifier, you will need to plug-type RSA "tulip".
- The design and color of illumination - here the choice depends on personal preference. Of course, good if the radio is well fit into the interior of the cabin. In some models, the brightness of the backlight can be adjusted, it can be a very useful feature.
Top models 2020
KENWOOD CMM-VT206
This is a fairly compact receiver 1DIN size for the installation does not require a tire with great depth. It can work with android application, and with a special proprietary applications Kenwood reMote. It has a classic design, very easy to use. Screen backlight - red
.The main parameters:
- Power 4x50 W amplifier;
- the internal sound processor;
- ability to play audio from USB and iRod;
- the availability of audio input on the front panel;
- Receiver with RDS;
- 13-band equalizer;
- communicate with devices on iOS and Android via Bluetooth;
- have RCA connector.
Advantages:
- excellent build quality;
- ergonomics;
- Support FLAS;
- a built-in amplifier;
- mobile calls in the "hands-free";
- ample opportunity to adjust sound transmission;
- a simple and clear menu.
Disadvantages:
- heating of the built-in amplifier can be observed after prolonged use.
Rioneer SRN-10VT
A unique radio in which your smartphone can become a direct part. It supports the ability to connect your phone and use it as a screen. In general, its parameters is a very decent model with a good sound. 1DIN size body, ie the device can be installed in almost any vehicle, even where space is limited. And while you get a full multimedia system with broad functionality. Thanks to the RGB-lighting, radio is easy to fit into any interior.
- lighting: RGB;
- Support for audio formats MDE, WMA, WAV, FLAS, ACC;
- EQ - 13-band graphic;
- built-in Bluetooth;
- 2 pairs of RCA.
Advantages:
- stylish design;
- excellent sound;
- Support FLAS;
- voice control;
- dubbing received messages;
Disadvantages:
- Static smartphone attachment, you can not rotate the screen.
JVC KD-T801VT
CD receiver JVC KD-T801VT - is the original model made in the amount of 1DIN, which is suitable for installation in almost any car. Due multipodsvetke buttons on the front panel of the device without problems fit into any interior cabin. This radio plays Audio Files in all popular formats, including FLAS. Compatible with iRod/iRhone. 13-band graphic equalizer can be used to adjust the sound. Cassette recorder also supports the control buttons on the steering wheel.
- power amplifier built-in 4x50 W;
- lighting: RGB;
- Technology JVCKENWOOD K2;
- supports JVC Remote App application;
- ability to play audio with CD, USB and mobile devices;
- Spotify support;
- Connect up to 2 phones simultaneously, and up to 5 - music playback;
- 2 pairs of RCA.
Advantages:
- detachable front panel;
- Support control buttons on the steering wheel;
- the original design;
- Support FLAS;
- excellent sound;
- Support iRod/iRhone.
Disadvantages:
- no usual encoder on top can be unusual.
Rioneer DMH-G220VT
This media station is made of 2 DIN, and is equipped with a large 6.2 "touch screen diameter. That is, you can not only listen to your favorite music, but also watch the video. You can connect to the mobile devices on Android, for that on the front panel has a USB connector. It is a digital radio that will not play audio CDs. Thanks to the built-in amplifier MOSFET and filter LF radio produces a sound in good quality. Built-in equalizer allows you to adjust the sound settings according to personal listening preferences. If necessary, to the head unit You can connect an external amplifier and subwoofer through RSA output on the rear panel.
- touch screen 6,2 ";
- ability to play audio from USB and mobile devices;
- 7-band equalizer;
- output for connecting the rear chamber;
- RCA.
Advantages:
- thoughtful design;
- the big screen;
- powerful sound;
- built-in amplifier;
- compatibility with devices
Disadvantages:
- easily soiled enclosure, for installation requires certain skills.
KENWOOD DMH7018VTS
Multi-radio with a large screen and Bluetooth. This head unit is made in the amount of 2 DIN size and has a touch 6.8 inch Touch Panel Control function display. Plays a variety of formats, the sound is excellent thanks to the built-in amplifier. Also worth noting is that a built-in sound processor enhances the ability to configure and adjust the playback. This head unit has inputs for connecting a rear-view camera, also has AV-in jack, video out and USB-port for connecting fleshnakopiteley and mobile devices. It can work as a navigator through a special application you can get information about traffic jams on the road.
- touch screen 8 ";
- the possibility of audio playback from USB and mobile devices, including iRod/iRhone;
- the internal sound processor DSP;
- filter low and high frequency;
- Support for memory cards SD
- 3 pairs of RCA.
Advantages:
- stylish design and ergonomics;
- compatibility with devices on Android and iOS;
- Support FLAS;
- Android Auto and Apple CarPlay;
- good sound and extensive customization options.
Disadvantages:
- no DVD (not for all of it negative);
- a USB-port.
In intrent store 130.com.ua you can buy car radio in Kiev, Kharkov and Odessa, the best brands, we have a wide range of models, relevant and today.
Materials
Car stereos: Best Sellers
