How to install the alarm on the car yourself
The task of car owners-to protect your car from possible theft or hacking. One way is to set the alarm: a high level of security and low cost. Experts say that the installation of such structures is nothing complicated. Of course, there are nuances, which we will tell you in this article, but this work is under the power of everyone. All you need: to be able to handle a screwdriver and understand a little bit in electronics.
Necessary tool
In principle, the installation does not need professional equipment, such a tool, at least most of it, is in every home:
- phillips screwdriver and key for 10 with a gate to remove the panel in the cabin;
- conventional knife, pliers for wire stripper;
- black duct tape;
- double-sided tape;
- multimeter for measuring the voltage of the network;
- foam rubber.
We recommend using high-quality materials, because they also play a role in the durability of the alarm.
Alarm setting
To begin with, we determine where we will install the Central unit of the system. It is best for the dashboard — and so-it all depends on your desires. Then proceed directly to the installation:
- Remove the two panels, steering and instrument: for this Unscrew the clips or screws.
- Remove the lower pad.
- You have access to the ignition.
- The connectors on the dashboard cannot be lowered on the metal surfaces of the body, so put some rags. Connectors can be wrapped with more tape.
- Now go to connect the wires.
Connecting the alarm to the control panel
At this point, follow these instructions:
- We connect the alarm outputs to the turn signals or dimensions, open door indicator, engine control.
- Find the bulbs turns on the back panel. On their main Board there are special tracks where you need to find a contact.
- We check the performance of the contact: we hook the connector to the track, turn on the turn and check the voltage.
- Just find the wire start control of the engine.
- And repeat these steps again with the lamp charging machine and emergency motor pressure.
- If the light is on, you have made the connection correctly. During each stage, be very careful.
Now we need to connect to the Central lock. We find the switch on the lock and carry out the same actions. as well as on the control panel of a car. Next, you will need to use duct tape: wrapped the harness to isolate them. Please note that you need to close only from the side of the alarm connector.
Let's move on to the next steps:
- Connect the wiring to the alarm unit.
- We connect the wires of the machine and our device.
- Stretch the cable under the hood of the security system.
- Attach the wire of the siren to the standard hole.
We're almost there. There is little left-just to block the motor with the ignition wire. Check: pull the wire from the lock and close. If the machine starts, you have correctly identified it. Don't forget to remove the jumper.
The last step is to connect the alarm and ignition wire. As you can see, the process of installing security devices is not so complicated.
At 130.com.ua you can buy car alarm in Kharkov, Odessa, Kiev with delivery in Ukraine.
Car alarm Sheriff ZX-750PROBuy4427 ₴ -
Car alarm Sheriff ZX-1095PROBuy5075 ₴ 4156 ₴ -
Car alarm Cyclone X-1000Buy2899 ₴ -
Car alarm Cyclone X-470DBuy2849 ₴
